BIKELAND > FORUMS > ZX12R ZONE.com > Thread: idle pulse NEW TOPIC NEW POLL POST REPLY
vmaxwayne
posted March 29, 2003 03:45 PM        Edited By: vmaxwayne on 29 Mar 2003 16:47
Idle pulse
Just installed Yoshimura RS3 system, PCIIR and the Kleen removal/PCV mod.
I'm getting a pulse at idle.
Goes away above idle.
Also the cold start used to idel above 2000 but now ~1500.
Any suggestions on smoothing out the idle and what rpm should it run on cold start??
TIA.
Wayne
kcadby
posted March 29, 2003 04:37 PM        Edited By: kcadby on 29 Mar 2003 16:40
These are all things that "happen to the bike" when you take the cork out of it's arss...
You can turn the screw on the high idle lever (right end of throttle bodies...you can see it move when you move the handle bar lever) OUT to raise the high idle some but the screw isn't long enough to raise the high-idle back to what it was with the stock pipes...
If you can...you realy should get your PC3 (bike) custom mapped somewhere that has the "Tunning Link" AND KNOWS WHAT THEY ARE DOING...
If the idle "hunt" REALY bothers you...you can turn the idle up to almost 1500 and it will be smooth (I prefer the hunt over CLUNKING into 1st gear)...
Go to the Dynojet web site...they have all the Tunning Link owners listed there...
0.29278898239136 seconds processing time
