BIKELAND > FORUMS > ZX12R ZONE.com > Thread: fast by frank map? NEW TOPIC NEW POLL POST REPLY
MO
posted November 25, 2001 06:23 AM
fast by frank map?
I like to give a new map a try but the fast frank map, actualy the timing portion looks quite different then most can I get some opinions befor I try this particular ignition map. thanks
KW
  Ignore this member    Click here to send MO an AIM message.
Zx23rr
Mahogany Bomber Pilot
posted November 25, 2001 03:47 PM
Try it....................
Just make sure you are running a 93 or higher octane for detonation. It would only show at the 2000-5000 if at all. The rest isn't that aggressive. If you live at a higher altitude, the less you have to worry! I run also the ignition pick-up 2.5-3 degrees advance on top of what is in the map. So if the map is showing 10', then actual is 12.5-13 degrees of advance. You will notice that the 100% will reflect or close to the Muzzy race after 2.5-3 degrees backed out.
Remember that I am running 2001 boots and 44/18 gearing.
You may install it, take it for a boot and slowly roll on more power as you feel comfortable. It will detonate in the higher gears(4-5-6th) if at all.
If you do, please give me any feedback. Check the notes on the map, as it has all the mods.
Later............................../
MO
posted November 26, 2001 08:42 AM
I will try it tonight, off to work now
KW
0.23826503753662 seconds processing time
