BIKELAND > FORUMS > ZX12R ZONE.com > Thread: piston to head clearance NEW TOPIC NEW POLL POST REPLY
ZX12-5807
posted April 12, 2012 11:24 PM
Just got my Cylinder and Head back from the machine shop where I had both resurfaced and the head oringed for the 1317cc block. I need to know what the minumum piston to head clearance would be? I put clay on the pistons then disassembled and measured and came out with .040". Is this enough clearance or should I ad another base gasket?
2001 ZX12
SBM 1317cc
Carillo Rods
Lee's Head
2001 ZX12 1287cc
2001 ZX12 1317cc Lee's head
psycho1122
posted April 13, 2012 04:06 AM
If I remember right, my 1270 w/ 14:1 CR was at .027
Ran great!
posted April 13, 2012 05:58 AM        Edited By: KZScott on 13 Apr 2012 14:04
psycho, was your .027 a direct measurement of the squished engine clay, or was it the clay minus half the oil clearances on the mains, rods, and wrist pin?
psycho1122
posted April 14, 2012 08:53 AM
Clay.
You could see where the pistons had no carbon build up on the exhaust side quench area. I asked Doug M. about that and his exact words were "That's Perfect"!!
It's tight, but keeps the combustion chamber detonation free on 91 pump set to 12.7:1 A/F.
I may be going back into the engine in the near future to check things out, look for issues and re-degree cams to 105/105 to go along with some additional head work.
Why do you choose 106/106?!?
ZX12-5807
posted April 16, 2012 09:05 PM
Did some research from previous discussions on here and I have come to the conclusion that my piston to head clearance is good. There are a lot of good threads on here on the subject. So thanks for the replys and information. Now on to finish up my motor, next is cam timing. I'm thinking 105/107 should be good.
2001 ZX12 1287cc
0.22737097740173 seconds processing time
