BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12r wont start NEW TOPIC NEW POLL POST REPLY
zx12rgreen
earth,sky,earth,sky ouch
posted April 10, 2012 07:20 AM
zx12r wont start
Ok guys after replacing clutch casing and changing oil and new battery got the beast to start.However i have an acumen cat 1 alarm that no longer disarms with either keyfob.I had to take out the fuse and the bike would then start.This happened for a couple of days but now nothing i do not hear the pump kick in just a click as i turn ignition on and a couple of clicks when i press the starter.I have checked the fuses and they are ok any suggestions.
supra5677
posted April 10, 2012 07:10 PM
What year is the bike?
zx12rgreen
posted April 11, 2012 09:45 AM
it is 2000 a1 model
supra5677
posted April 11, 2012 11:17 AM
Try Ridge Racer
mbially@olympus.net
tuusinii
posted April 11, 2012 11:09 PM
Is it giving any DFI errors? I'd first remove the alarm completely because probably it's doing what it should - preventing starting.
tuusinii
posted April 11, 2012 11:10 PM
Is Your battery fully charged?
denisrod1979
posted April 13, 2012 05:18 AM        Edited By: denisrod1979 on 13 Apr 2012 13:21
tuusinii could be right, sometimes these batteries show full charge but are drained...hook up your motorcycle battery to your vehicle battery .. BUT DO NOT CRANK UP YOUR CAR because it will fry your whole wiring harness, and try and start it then, this will tell you if is the battery or not...most times they're the problem...especially when you load up too much crap on your bike...alarms, and other crap...good luck!
harryzx-12
posted April 19, 2012 03:08 AM
This will cause lots of issues. Make sure the battery is good. I know you said it's new but i would check it to eliminate it as the problem.
Paul2281
posted April 19, 2012 12:52 PM
Sounds like what Harry is saying.... 11.8 isn`t enough....Put a load tester on it if possible....
zx12rgreen
posted May 12, 2012 10:51 AM
Soz for the delay it was my acumen cat 1 alarm had it taken off now all ok
0.23747181892395 seconds processing time
