BIKELAND > FORUMS > ZX12R ZONE.com > Thread: MPH OFF NEW TOPIC NEW POLL POST REPLY
peanut 12
peanut 12
posted April 09, 2012 07:02 AM
MPH OFF
i have a 2000 zx12 i bought from north corolina and it has a 87mm big bore 5mm stroke and cnc port and web cams but my mph is just 145 in the 1/4 what could it be
supra5677
posted April 09, 2012 09:30 AM
Dang. You have a 1427 with cams! You should have at least 225 to the back tire. How much do you weigh? How is the bike geared?
supra5677
posted April 09, 2012 09:31 AM
Compression test?
peanut 12
peanut 12
posted April 09, 2012 10:43 AM
i weigh 180 geard 16-46
peanut 12
peanut 12
posted April 09, 2012 10:44 AM
can i do a compression test my self what do i need
supra5677
posted April 09, 2012 01:57 PM
http://www.dansmc.com/compression_test.htm
posted April 09, 2012 09:24 PM
forget about doing a compression test, do a LEAK DOWN test. so many things affect a compression test.... compression ratio, valve sealing, rings sealing, cam timing..... a leak down will pinpoint any mechanical problems.
shiphteey
posted April 10, 2012 07:00 AM
Or you could start with just the basics like listing your weight, your bike's weight.
Also a headwind and hot temps can steal MPH too.
Maybe your tuck sucks.
A.
Gemini Motorcycles
0.25159502029419 seconds processing time
