BIKELAND > FORUMS > ZX12R ZONE.com > Thread: How much timing do you run at idle? NEW TOPIC NEW POLL POST REPLY
smokeysevin
ZX12r-STX15f hybrid motor
posted March 08, 2012 04:01 PM
I am working on an ecu map for what is basically a low compression long stroke zx12r 12.0:1 cr and 69.2mm stroke and stock bore.
I am having some issues choosing my idle timing, right now I am bouncing between 6 and 8 degrees btdc. Yesterday it fired right up with 6 degrees and today it wouldn't start with less than 8.
What do you run?
Sean
1498 cc
69.2mm stroke
83mm bore
tuusinii
posted March 09, 2012 12:00 AM
Stock it's 10 degrees. I run 11.1.
smokeysevin
posted March 09, 2012 05:27 AM
Thanks for clearing that up, I found 2 maps.one with 7 and one with 10. I had started with 3 degrees and needless to say it ran like crap.
Sean
1498 cc
69.2mm stroke
83mm bore
supra5677
posted March 10, 2012 03:28 PM
That's a big nasty stroke you have there!!!! How did you do that???
smokeysevin
posted March 10, 2012 03:33 PM
Its the stock stroke for kawasakis ZX12r based jetski engine. We get a standard dimension 12f which is exactly the same as the zx12 and we also get the motor I have which is a 1498 cc stroked version. The 12f is 11.2:1 and the 15f was 10.6:1 both have very lazy cams but are good to use if you have a turbo or supercharger. I dont so Im using the more aggressive bike cams and 12:1 pistons.
Sean
1498 cc
69.2mm stroke
83mm bore
supra5677
posted March 10, 2012 03:47 PM
Where did you find the motor? That sounds like cool project..
smokeysevin
posted March 10, 2012 04:03 PM
I bought the ski for 500 dollars almost 4 years ago. The motor was stock and I built it up and am trying to get it ready to ride for this week.
Sean
1498 cc
69.2mm stroke
83mm bore
0.23710489273071 seconds processing time
