BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Inside of a muzzy pipe after 10k miles? NEW TOPIC NEW POLL POST REPLY
your car is slow
Fuck Nitrous...Got Boost?
posted March 12, 2003 05:41 PM
Well...this would explain why its so loud (yes thats all that remained of the packing)
Inside of pipe
Inner baffle
Pipe going off to be ceramic coated black...new packing on the way
Do not taunt happy fun ball!
posted March 12, 2003 06:39 PM
Purty!
RAC4IT
Bergie
posted March 12, 2003 07:21 PM
Mine looks the same. It can't be good for power.. actually I've been told they actually perform better full of fiberglass packing material vs. than without like what you have shown in the photo above. One question, why did you drill out the rivits on the Muzzys name plate?
your car is slow
posted March 12, 2003 07:52 PM
Pipe is being sent off to be ceramic coated black...I wanna put the muzzy plate back on it when its done.
and when it comes back...im sending mikes off to get done
Zhooligan
Post Whore Extraordinaire!
posted March 12, 2003 09:09 PM
I persoanlly have found the packing goes really fast in the MUZZY can. Your picture is pretty similar to what I have found after 2000 miles or less. And Bergie your comment is what I have been told by a number of experts as well.
future; -- Youth is forever.
blink
posted March 13, 2003 02:35 AM
I have 2 of the Muzzy Titanium oval cans. 1 pipe has been modified by removing the baffle and packing and replacing with a section of 2.25 I.D. exhaust pipe. Although I kind of like the sound (loud) I did Dyno test the modified can against the stock can and regardless of which maps I tried the end result was an 11 horsepower loss in peak horsepower with the modified can due to the loss in back pressure.
your car is slow
posted March 13, 2003 06:40 AM        Edited By: your car is slow on 13 Mar 2003 06:41
wow....thats insane carl!!!
Anyone have any idea of a better packing material to use besides whatever muzzy provides?
What do they use in regular car mufflers? Ive torn apart some pretty damn old mufflers and STILL found that packing in there.
Someone mentioned they use regular fiberglass insulation (like the pink panther shit)
I think perhaps ill try a variety of packing material...I have two pipes to play with (mine and mikes). I think Ill fill mikes with cocoa puffs first
posted March 13, 2003 08:13 AM
My War story is that we packed the cans real loose to get through AMA Inspection on the noise meter, then went back and repacked then very tightly, but we all used woven mat fiberglass! A lot stronger and less prone to blow out!
your car is slow
posted March 13, 2003 08:19 AM
Woven mat fiberglass?
Where would you obtain this? Home Depot?
TedG
posted March 13, 2003 08:46 AM
I had pretty good success with a layer of super course steel wool (0 ought)
then the regular packing. The Steel wool acts like buffer to prevent the packing from being sucked up and burned. Fine steel wool will not work it just burns like the packing.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
your car is slow
posted March 13, 2003 09:20 AM
Ok..that just jarred somethin lose.
I was watchin a show the other day like that bob vila "this old house" kinda stuff...and they were using this insulation that looked like steel wool...I think he called it "mineral something". Man...that shit rocked....he basically put some in a bucket and dropped this insanely loud personal screamer device inside the bucket....couldnt even hear it. Anyone know what this stuff is? Would it stand the heat?
posted March 13, 2003 10:01 AM
Gentlemen,
None of the muffler manufacturers use "fiberglass" or anything like household insulation. In particular, the packing we use has changed of over the last couple of years (the packing and the muffler shown looks to be about 2 years old). The packing we use is the same as is used in many OEM automotive applications. It is a high temperature ceramic material designed by a major world-wide supplier for just this type of application. You won't find anything better in general use "over the counter". Just take care of your muffler, remember dynoing and top speed passes will eat it up pretty fast and keep in mind that loose and loud is less, not more, power. As you know, we sell repack kits and also will rebuild and re-polish you mufflers if you send them to us for re-pack.
kcadby
posted March 13, 2003 10:24 AM
IF???you want to use the fibreglass...go to a Marine supply place (boat building material)...
kcadby
posted March 13, 2003 10:27 AM
Doug...YCIS has run a LOT of NO2 through that puppy also...
The muzzy kit IS worth the money IMHO...comes with a NEW baffle tube also...
your car is slow
posted March 13, 2003 10:38 AM
Yes...as kevin mentioned...Ive run quite a bit of nitrous and racegas through that pipe..and its held up quite nicely
Is the new baffle any different than the one I have? bigger holes? smaller holes? good? bad? wha?
Talk to me goose
posted March 13, 2003 10:55 AM
Oh yeah, and N2O burns 'em up faster, especially if you get the dredded "bangin".
The baffle tube is unchanged.
Doug
your car is slow
posted March 13, 2003 11:11 AM
preciate'cha as usual doug!
REDRIDER
posted March 13, 2003 11:58 AM
I think it's called rock wool.For sound insulation only.
posted March 13, 2003 01:55 PM
That is where I got mine! It sure took a lot longer time to burn up than anything I ever used! Around the core it was really charred, but white in the center and yellow at the shell!
RAC4IT
Bergie
posted March 13, 2003 02:44 PM
Doug what is the cost of having a Muzzys round carbon canister on titanium repacked and polished, and returned? We have two on our racebikes is in a similar condition as shown above.
posted March 15, 2003 09:00 AM
If you send us the muffler, we rebuild it for 48.95 including packing but less any damaged, unusable parts, plus freight. We send you packing for $28.95 plus shipping if you want to do it yourself.
Doug
posted March 16, 2003 06:16 AM
I Dyno'd tuned the Red 2000, has a PC3r, K-Ns, Muzzy blockoffs, 17-46, Muzzy Ti/Carbon can without fiberglass and got 177.1HP , 92.3lbs.Torque
your car is slow
posted April 03, 2003 09:13 PM
and what it looks like after its back from being ceramic coated
Got my pipe back from J&D performance coatings in callahan....its AWESOME!!!!
I shoulda done this long ago.
here is a pic
Even did the inside...supposed to widthstand temps up to 8 or 900 deg I believe.
aliveagain
posted April 04, 2003 08:45 PM
Last time I had to repack a can was off of a bassani pipe in the 80's.I believe I used boiler insulation.
0.25268411636353 seconds processing time
