BIKELAND > FORUMS > ZX12R ZONE.com > Thread: will not start NEW TOPIC NEW POLL POST REPLY
causey
posted February 28, 2012 05:11 PM
will not start
I found a new motor put it in turns over but will not start.I have trouble shooted everything I could think of. It's getting fire fuel no codes and everything is in place does any one have any ideas
Ron causey
herbg26
posted February 28, 2012 07:32 PM
What year is your bike(referring to the ecu) and what year motor did you put in. You may need to re-index the camshaft..
Or did you mix up the connectors for the map sensor and throttle position sensor, but I guess you would have gotten a code if you did that..
Herb
Kawasaki lover
tuusinii
posted February 28, 2012 11:02 PM
Does the fuel pump cycle and prime the fuel system? Do clocks sweep when turning on ignition? Do You have enough power in the battery - whats You're voltage when cranking? And are You in neutral and NOT using clutch? Side stand switch? And You do have fresh fuel in?
causey
posted February 29, 2012 02:08 AM
Fresh fuel kick stands down its in neutral fuel pump cycles clock sweeps its a 2000 with a 2000 motor
Ron causey
causey
posted February 29, 2012 02:10 AM
I put the old cam sensor out of the first motor in the new motor as well.its a new battery with cables hooked to it
Ron causey
Pudsky
posted March 01, 2012 08:24 AM
Ron, the motor is a 2001
herbg26
posted March 02, 2012 02:52 AM
Ron,
This thread shows how to re-index the 01 exhaust cam to run with 00 ecu.
http://www.bikeland.org/board/viewthread.php?FID=1&TID=43797
Herb
Kawasaki lover
Greenisbest
posted March 04, 2012 10:16 AM
Do you know for certain the Motor you installed is good ?
END OF MESSAGE !
jhinderliter
Hacksaw
posted March 05, 2012 05:58 PM
+2 on what herb said...
also might make sure you didnt mix the plugs up on the MAF and TPS..
My other ride is big and green too!!
0.25699710845947 seconds processing time
