BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Resistor mod for NOS NEW TOPIC NEW POLL POST REPLY
wannabe
posted March 11, 2003 03:56 PM
OK, I don't remember where I saw this, but I thought I would post here to try to get you guys to help me to understand this. I read somewhere about someone putting a 1000 ohm resistor in series with the temp. sensor to fool the bike into richening the mixture when running a dry shot of NOS. Here are my questions:
1. Is this the 'resistor mod' that I keep hearing about?
2. Does the extra resistance make the bike think that it's running hot/lean?
3. Is this something that people do if they're too cheap to buy and install a PCIIIr?
"There are only three sports: bullfighting, motor racing, and mountaineering; the rest are just games." - Ernest Hemingway
Cowboy
posted March 11, 2003 05:41 PM
1.Yes
2.IT UPS THE FUEL I BELIEVE 8% ACROSS THE BOARD
3.Yes,we did this before the pc3 came out to take some of the stumble out when a aftermarket pipe was put on.Now i still use this instead of a powercomander because i have never seen one fail as i have witnesses and heard of alot of pc3r fail.
Use a 1/4 watt 470ohm resistor
wannabe
posted March 11, 2003 09:50 PM
Thanks, Cowboy. I'll remember that if my PCIII ever takes a crapper.
kingzx12r
woo hoo
posted March 12, 2003 11:19 PM
kingzx12r
BAM
Posted: 10 Mar 2003 05:00 Post subject:
I think there are some tuning issues here nitrous is dangerous in any motor if not tuned properly, I have three bikes with dry shots 285 hp stock motors in them all the temp change in the box will up the maps approx .08 % with a 30 shot across the board, the resistor mod on the coolant temp sensor will up that to 14% with a 640 ohm 1/4 watt resistor and will go as high as 21% with a 1000 ohm !/2 watt resistor which is good to 50 hp dry with a/f at 12:1 or 13.5:1 at 60 hp. What do you want to know about the dry system I designed one for my 12 feb 00 on the prototype Kawi had nad have done close to 200 bikes personally and never had a problem or complaint except for two people tossing shims with a shifter atr rev limiter. The question on the 56 and two 38 pills will vary large on setup and proper tuning with two 38 jets from nos with the resistor mod and c-16 fuel you will have 247-253 hp at the tire, the 56 pill from nos with same mods will give you 251-262 hp, the difference is that the twins will be a two stage system and ramp power differently then a single 56 which will ramp power very quickly. Please feel free to email me at home with any dry nitrous questions.
ARH: I find that most have no idea about nitrous and I go out of my way with all my customers on how nitrous works and what to watch for I'm not here to bash just update some well needed info apperently.
Wayne
_________________
Going too fast doesn't kill you, it's the abrupt stop that does it.
lawson4@axxent.ca
It ain't easy being me.
coolrunning12@hotmail.com
lonniemac
posted March 13, 2003 05:52 AM
thanks for the info . can you supply dry shot system if so let me know
kingzx12r
woo hoo
posted March 13, 2003 12:11 PM
Yes we do email me at the address below.
0.22558689117432 seconds processing time
