BIKELAND > FORUMS > ZX12R ZONE.com > Thread: chain lube NEW TOPIC NEW POLL POST REPLY
quickrev
posted March 04, 2003 10:30 AM
chain lube
Anyone have a favorite chain lube that won't completely gunk up my swing arm?
kawachan
posted March 04, 2003 11:20 AM
http://www.bikeland.org/board/viewthread.php?FID=1&TID=6158&set_time=
RED NINJAS RULE!!
tbbt
posted March 04, 2003 11:22 AM
Chain lube and oil test:
http://www.bikeland.org/board/viewthread.php?FID=1&TID=4436
AKA: T^2
tbbt
posted March 04, 2003 11:43 AM
AKA: T^2
tbbt
posted March 04, 2003 12:03 PM
My preferences:
Oil: Mobil MX4T
Chain Lube: PJ1 Black or Blue
Note: Currently I'm using PJ1 Blue. It works well if applied correctly (applying correctly greatly reduces sling-off). I selected it over the Black because the Blue is supposed to be specifically for O-Ring type chains. The Black is supposed to be for non O-Ring chains. However, the article the I refered to above says that the Black is also O-Ring safe. So, I might give the black a try the next time I go and buy a can.
AKA: T^2
quickrev
posted March 04, 2003 12:33 PM
i'm using a honda brand chain oil that creates the biggest mess you'll ever scrape off your swing arm...I better try the PJ1, thanks for the posts guys.
tbbt
posted March 04, 2003 12:46 PM
The Pro Honda HP Lube has a better score than PJ1 in the sling off category.
Proper application is important in reducing sling off. Things that I focus on when applying lube:
- chain has been properly cleaned and dried
- chain is warm before applying lube
- only enough lube is applied to get the job done (too much lube will greatly increase sling off)
- lube is allowed enough time to set (to allow the solvents to evaporate)
AKA: T^2
quickrev
posted March 05, 2003 11:17 AM
a warm/hot chain, thats probably where my problem is....
0.2319450378418 seconds processing time
