BIKELAND > FORUMS > ZX12R ZONE.com > Thread: wtb good pc111r NEW TOPIC NEW POLL POST REPLY
zx12mark
posted October 25, 2011 09:12 PM
wtb good pc111r
i will load my custom map.
posted October 26, 2011 09:51 PM
Will check my box in garage
hurricanefibers
posted October 27, 2011 02:00 AM
I have a PC3-usb for a 2002 zx12r
zx12mark
posted October 27, 2011 06:09 AM        Edited By: zx12mark on 27 Oct 2011 14:11
i have had a pc3r on my bike (2000 zx12r) for 10 years.long painful 2 year story why i`m wanting to get another pc3r to test with.i do run timing advance in 2 areas of rpms. plus2 degrees from 0-6000 rpms then plus 4 degrees 10000 to 13000 rpms.so i have to have a pc3r.
tuusinii
posted October 27, 2011 09:36 PM
Why not upgrade to the ECU flashing? The ignition timing for example is quite wierd. There are for example very big advance (~45 degreeds) in 3000-4500 RPM when throttle is low. Also You can change both alpha-n and speed density maps. I was able to get much smoother running engine with ECU tuning. Most notably the 420RPM buzz is gone. Also my cruising mileage has ingresed about 25% (from 31 MPG to 39 MPG). Also couple extra ponies also
0.30213689804077 seconds processing time
