BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Brake Bracket VH Style & Step Hindle! NEW TOPIC NEW POLL POST REPLY
posted February 14, 2003 06:28 PM
The bracket over the Arm is a tight fit, but I added the 8 mm bolt for insurance. When the weather gets better, I will remove the arm and weld a Bracket about 6 inches long 1/4" thick and about 1.25 Inches wide! with about 4 holes, I should have all postitions covered
Ready for an Oil change and testing next weekend
That Brake disc is the Ferodo Full Float!
xtremespeed
posted February 14, 2003 07:18 PM
Looks pretty good VH. Too bad it was necesary for you to do yourself. I got my Hindle this week. Same as yours. Did you use any gaskets or sealer on your setup?
posted February 14, 2003 10:56 PM
VH why does your oil look green in the site glass?
MM
vozizm
Got Nothing Witty To Say
posted February 15, 2003 03:46 AM
Good job sir!
VOZ
Hells Dark Lord
living life, and loving it.
posted February 15, 2003 04:00 AM
not to shabby if I say so myself.....lol
posted February 15, 2003 05:40 AM
MM, First, you are correct, it does have a "Green color" I guess that comes from the Grapes Seeds they use as part of the Oil Package! Motul E-Tech 100. All syn, but 1/2 the price of 300V
I am still surprized that no one jumped on me for the 2 drips on oil on my pipe!
Extreme, I posted this on Labusas also , but "I keep a supply of gaskets! I mount them with the split the Pipe. I also use high temp Silicone also, how else will the pipes com apart that easy?" I also said if your "S" Pipe does not fit easily, then Squeeze the "Oval" part of the end of the collector near the weld in soft jaws vice in about 1 inch to return the round retenetive memory! Then easy fit! The connection is Very Tight!
posted February 15, 2003 05:42 AM
Means a Lot when it comes from one of my newer Hero's! You are the MAN HDL!!
kcadby
posted February 15, 2003 10:47 AM
I though he had coolant instead of oil!?!?!?
Looks real good Vincent...
2 oil drips??? CLEAN THE FREEKIN CASES!!!
Just kidding...I KNOW you ride yer bike a LOT and...John's bike (I hate saying this but it's true) is WAY worse than that...
posted February 15, 2003 04:57 PM
Kevin, I was just surprized I wasn't given both barrels for the oil on the Pipe! The Bike is dirty and it is too cold to clean it like I want to! I did this just before the Snow Storms and Now I can clean My shop and tool Boxes over the weekend since I cannot do 1 thing outside (You know whatr I am talking about!) I have to clean my Work Bench so I can pull my Drill Press forward to drill, Tap and install stainless TIME CERTS in the Bars used to mount the foot Pegs / front of the race seat!
I will be doing some testing on the 22nd between Stock Boots, Original Stacks, New Stacks and a set with a less than smooth finish! I will post the results, Good Bad Or Ugly!
0.30047583580017 seconds processing time
