BIKELAND > FORUMS > ZX12R ZONE.com > Thread: New Clutch Question??? NEW TOPIC NEW POLL POST REPLY
Levi_ZX
posted May 10, 2011 05:42 AM
Just finished installing a complete Barnett Clutch kit in my '00 ZX12r over the weekend.. New steels, friction plates, and springs
the question= When I launch the bike (dragging my clutch) I'm hearing a grinding right before i'm fully off the clutch.. Now if i just dump the clutch and get on the gas..No grind and all is good. Is this grinding just because they are BRAND NEW plates and will go away after a few launches at the strip or do i need to adjust the clutch more???
Thanks in advance for any input on this matter... Levi
p/s: the bike pulls like a scalded dog in any gear and any rpm so the clutch is for sure doing it's job properly.. Thanks
Paul2281
posted May 10, 2011 01:22 PM
Did you check to see were your stack height ended up with that kit??? Not too many people ever use a Barnett clutch kit in their zx12.... OEM is the clutch plate to choose....Barnetts seem to swell up with heat and change adjustments a bit.... Did you use the chatter rings???
Levi_ZX
posted May 11, 2011 05:24 PM
NEVERMIND!!!!! FIXED IT...... ANTI CHATTER RINGS ARE NOW GONE AND PROBLEM SOLVED
Levi_ZX
posted May 11, 2011 05:27 PM
WILL BE GOING WITH OEM AS SOON AS THE BARNETT PLATES ARE TOAST WHICH SOUNDS LIKE IT WON'T TAKE LONG.... THANKS Paul2281
twista
" Get up, and Stay up ! "
posted May 12, 2011 04:56 PM
i doubt that was the problem!
Ken 12r
posted May 13, 2011 09:48 AM
Did you soak the frictions in oil at least overnight ??
www.uklandspeedracingassociation.co.uk
posted May 15, 2011 07:20 AM        Edited By: KZScott on 15 May 2011 15:21
IIRC Doug Meyer once said that all you need is to get them a little wet with oil (with your finger or whatever) when you put them in, that soaking isnt needed, but doesnt hurt. thats the way ive been doing it since i started racing the 12 a few yrs ago
James R Mikus
posted May 17, 2011 06:00 AM
Just joined and I need the stack height for a 2000 ZX12.I run a Muzzy billet basket.MTC single stage lockup...Thanks James
biggmoinc
posted May 17, 2011 08:51 AM
56.8-57.6, go as close to the bigger number for wear purposes
biggmo@aol.com
James R Mikus
posted May 17, 2011 09:03 AM
Thanks,appreciate the quick response...James
biggmoinc
posted May 17, 2011 09:07 AM
No problem
biggmo@aol.com
0.21696591377258 seconds processing time
