BIKELAND > FORUMS > ZX12R ZONE.com > Thread: quick zx12 question NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted April 04, 2011 03:42 PM        Edited By: 1badzx12r on 5 Apr 2011 00:07
quick zx12 question
does gen 1 parts swap or interchange with gen 2 motor parts like will a crank from an 05 fit into an 01
almost_les
posted April 04, 2011 06:53 PM
alt rotor, stator, cam pickup, motor mounts (therefore heads), and oil pumps are diffferent. i think thats about it
posted April 04, 2011 07:02 PM
the 05 crank will fit but you will need to use the stator and crank pos sensor rotor from the 01
1badzx12r
posted April 05, 2011 05:11 PM
looks like everything is coming together OK .. should have it up and running by tomorrow evening . I'm going to used the 05 wiring harness and ecu .. trying to use as much 05 stuff as possible.. found the reason the 01 went to shit ..somebody miss match the oil pump gears using an 01 outer and a 02 inner ..which broke the ears off the shaft and fried the motor ..
1badzx12r
posted April 05, 2011 05:12 PM
oh and a zx12 is a bitch to work on .. zx14 much better ..
1badzx12r
posted April 06, 2011 05:59 PM        Edited By: 1badzx12r on 7 Apr 2011 02:00
started it up today .. had the same out come broke the oil pump shaft again .. i shut it down before any damage .. but WTF .. This was a match used gears.. order a new set and will try again in a week ..
posted April 08, 2011 06:49 PM
no junk in it? pin in the correct spot?
1badzx12r
posted April 11, 2011 07:18 PM        Edited By: 1badzx12r on 12 Apr 2011 03:20
put all brand new parts in it and it work like a champ ...bike really sounds good . even with 06 zx14 injectors ..
posted April 16, 2011 08:48 PM
zx14 injectors are a direct swap??
1badzx12r
posted April 19, 2011 01:57 PM
yes they are ..i put a set from an 06 zx14 into 05 zx12 throttle bodies ... from what i've read and learnt ...the 05 zx12 are 390cc and the 06 zx14 are 440cc..
0.40903115272522 seconds processing time
