BIKELAND > FORUMS > ZX12R ZONE.com > Thread: forks NEW TOPIC NEW POLL POST REPLY
Tarnac Tyrant
flawless cowboy
posted March 24, 2011 01:14 PM
forks
hi all,i want to fit forks that will accept radial calipers,i found set of zx10r 2006 forks,will they fit??? i fit new inner bushings to my forks and one of the bushes is from a zxd10r and the other was from an r1,so they maybe the same thing right? thoughts?!
top of the mornin' to ya
Tarnac Tyrant
flawless cowboy
posted March 24, 2011 02:38 PM
by the way mines a b2
zxboy
posted March 25, 2011 03:47 AM
I'm pretty sure the 04-05 zx12 models had radial mounted calipers
chuck762
posted March 25, 2011 04:34 AM
The ZX10 forks will not bolt into your triple clamps. You need to swap the entire front end over to ZX10 parts. Some issues are the handle bars are lower. You will need to fit the ign. switch and other details. It has been done but it is easier to find a set of 04/05 ZX12 forks as they are a bolt on item.
Tarnac Tyrant
flawless cowboy
posted March 27, 2011 07:37 AM
nice one chuck thanks for reply
Hells Dark Lord
living life, and loving it.
posted April 02, 2011 03:01 PM
I dont know about the 04, but the 05 ZX12 had radial calipers and would be a direct bolt in to the B model clamps....dont forget to get the matching master cylinder and calipers.
chuck762
posted April 04, 2011 01:33 PM
04/05 and 06 in europe are all the same radial mount set up forks. The master cylinder is the same as on the earlier models. They did not get a radial master cylinder like the ZX6/10/14 did.
You can use almost any of the japanese made radial calipers with the proper spacers on the ZX12 forks. You can run the 04/05 rotors or with spacers you can use the 320mm 00-03 rotors.
The Zx14 calipers seem popular with most people for some reason.
Hells Dark Lord
posted April 05, 2011 01:26 PM
easier to just get the matching rotor and caliper off the bike you get the forks from, then you know it all fits and there is no need for spacers....
chuck762
posted April 07, 2011 07:09 AM
If we all did it that way then why bother swapping forks or brakes at all. There have been improvements in calipers, master cylinders and rotors since the ZX12 radial set up was first introduced so why not take advantage of it. It isn't rocket science matching a spacer up fit a certain sized rotor.
Race teams have been doing it for years and that the fact it is so easy to change rotor size is one reason radial mount brakes came about.
Hells Dark Lord
posted April 07, 2011 04:15 PM
hey if you have the money and time to fiddle with it....I am running EBC rotors, with EBC pads and Stainless lines and my brakes work just fine.....can stand it up on the front wheel anytime I want with 2 fingers.....Just Sayin
jhinderliter
Hacksaw
posted April 22, 2011 10:36 AM
im running the same set up and having good luck with it.... id replaced the stock rotors several times after i fried em :/ so i spent a little coin and went with the EBC stuff...
My other ride is big and green too!!
0.2226140499115 seconds processing time
