BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Best Battery for a Big Bore NEW TOPIC NEW POLL POST REPLY
Megabyte
posted February 02, 2003 09:26 AM
Looking for a new battery for my 1361, and would like one w/ more cranking power than stock. I've read posts about the Interstate (gel) battery, but haven't read any details on it or any other battery that's presented a persuasive argument for switching from stock.
Thanks,
posted February 02, 2003 10:07 AM
MB,
MadMike will weigh in on this topic! But basically the OEM is 170? CCA's, Interstate gel is 220? CCA's with 5 sec of 500+ CCA's. I am getting a 280 but it will not fit in the battery box. When the 1361 gets hot the OEM doesn't cut it (my experience).
good luck!
posted February 02, 2003 12:57 PM
did you talk with the guys at the store? and Ill let other people tell their stories....
Mad Mike
posted February 02, 2003 05:09 PM
Entropy - did you try going to -5 degrees on the PC3 at 1000 rpm? Since yer only there when starting, it really doesn't affect anything except the ability to start.
Megabyte
posted February 02, 2003 10:23 PM        Edited By: Megabyte on 2 Feb 2003 22:37
MadMike,
Does the Interstate Gel battery fit in the 12's battery box?
You have email
posted February 03, 2003 01:51 AM
swft,
I haven't yet done the -5 at 1000,1500 but will this week. what fuel are you running at the same rpms. I'm thinking of bringing that down also
posted February 03, 2003 01:52 AM
swft,
posted February 03, 2003 05:21 AM
I will email you the correct Gel battery that fits, it is a 220 cca. I am working on a Mod for the Battery box right now to fit the 270cca battery.
Mad Mike
Megabyte
posted February 03, 2003 01:23 PM
I talked to the store, Interstate just relased the YTZ14S 230 CCA battery that is actually smaller than stock. Do you have any thoughts on this one?
Mad Mike
posted February 03, 2003 07:11 PM
you have mail...
krexken
posted February 03, 2003 08:33 PM
I tried retarding the timing at cranking rpms but had no affect. Cracking the throttle a little helps immensely. Original battery on my 00 turning my big motor over fine. I'm sure I just jinxed myself though.
Zhooligan
Post Whore Extraordinaire!
posted February 03, 2003 10:06 PM
Hey mike if you could let me know the correct gel battery as well.
Thank you.
posted February 04, 2003 09:27 AM
The correct battery to use would be the "YTX14-BS", now I am experimenting with the larger "YTX20-BS" but I do not have any information about that one yet, If I can get it to work you will have slightly more weight then stock, but the AMP's and cca will go up greatly. by the way, FYI for you guys the "New" Batteries have greater cca. the 14 is now 210cca, and the 20 is 310cca. hope this helps and if I can get the 20 to work I will let everyone know ASAP!
Mad Mike
Megabyte
posted February 04, 2003 01:00 PM
Thanks for the helpful info!
Mad Mike
Megabyte
posted March 17, 2003 12:46 PM
Mike,
How did your "experiment turnout?
Mad Mike
0.24032115936279 seconds processing time
