BIKELAND > FORUMS > ZX12R ZONE.com > Thread: please help!!! NEW TOPIC NEW POLL POST REPLY
zx12r2001
posted December 25, 2010 08:37 AM
please help!!!
Well I am new to the forum and have an issue with my clutch. I upgraded to a muzzy clutch a couple of years ago and recently started having problems. The bike starts fine and about 5 minutes into a run I pull in the clutch to stop and loose all pressure in the lever and as the bike comes to a stop I get some clunking noises that I can also feel through the pegs. After that I have no clutch pressure at all and cant get the bike back into neutral. After the bike sits for a bit and I start the bike back up I can get it back into gear, but the same issue happens all over again. Please help!
miketmmns
posted December 25, 2010 04:59 PM
There are several threads on the 12 clutch. Look through them and they should help. Sounds like your clutches are wore out past the limit.
posted December 25, 2010 08:52 PM
Broken plate or a worn, "notched", basket are possibilities
shiphteey
posted December 26, 2010 07:32 AM
Did you get the upgraded billet basket from Muzzys? Either way If I were you I'd take it to a reputable shop if this is over your head. If its just fibers that need to be worn I'd still look into the billet basket, especically if you're gonna ride this bike hard out the gate.
A.
Gemini Motorcycles
zx12r2001
posted December 26, 2010 10:27 AM
Thanks for all the suggestions! I will start by changing the clutch pack out and see what happens. thanks again.
J
posted December 26, 2010 01:51 PM
get pics of everything
shiphteey
posted December 27, 2010 05:43 AM
Post pics here, someone may find something disasterously wrong. If the basket blows up while you're riding it gets expensive....very expensive.
How many miles do you have on the muzzys clutch and what type of riding?
A.
Gemini Motorcycles
zx12r2001
posted December 27, 2010 02:17 PM
I have about 3,000 on the Muzzy and just do regular street riding. I have had the basket and clutch fibers out so I know the basket is fine. The stack height does look a little low so i guess that's where I will start. I do have a power commander with a quick shifter and have read that they tend to prematurely kill the fibers. Does that sound correct?
shiphteey
posted December 28, 2010 08:12 AM
I would think clutchless upshifts wouldn't hurt the clutch at all, its using the clutch between shifts and WOT applications that could risk hazing the clutch. From 2nd on up you shouldn't use the clutch in spirited riding.
A.
Gemini Motorcycles
posted December 28, 2010 10:54 AM
What Ship said.
wylde
posted December 28, 2010 04:51 PM
i shift without for 30 years with no failure and my DJ quickshifter is set at 8000rpm, and would hurt even less as it applies the slack in the drive train for you.., if you want give me a call i might be able to lead you in the right direction,, PM sent
There you go again,,NOT being aware of yourself !
posted December 28, 2010 08:30 PM
I just thought of something- Make sure you look at the springs in the base of the basket. They break.
zx12r2001
posted January 08, 2011 06:09 AM
Well......I took the clutch apart and found out that the needle bearing that goes on the puller shaft was all busted up. I replaced that along with the springs and clutch pack with new oem stuff. Started it up but couldn't ride because we have snow here in the east, but put the bike in first but wasn't able to upshift or get it back into neutral with bike running. I turned the bike off and then was able to get it back into neutral. I looked in through the oil filler hole while bike was running and was gettiing oil lubrication and when I pulled the clutch in it opened up. When I tore into the clutch everything obvious looked good. any more ideas?
thanks,
posted January 08, 2011 09:22 PM
brand new clutch paks always drag for just a lil bit.
don't worry about it. After yr first ride it ill be fine.
this is assuming you have about 1/8" freeplay in yr clutch adjuster (on yr left lever).
Kwakrider
posted January 11, 2011 03:21 AM
Did you pre-soak the fibre plates before instalation? Otherwize they will drag..
swolldaddy
posted January 28, 2011 03:39 PM
I have a 2002 kawasaki zx-12 I spin a #3 bearing I have a big crank what size bearing do I need to go back with and how and where can i find them
posted January 28, 2011 03:48 PM
I have a 2002 kawasaki zx-12 I spin a #3 bearing I have a big crank what size bearing do I need to go back with and how and where can i find them[/quote
what area are you in?
sounds like it might be useful to find a good builder in yr area.
swolldaddy
posted January 28, 2011 04:10 PM
where can I find a built motor for sale or would it be cheaper to rebuild my motor
i
Stuart Racing
N.H.R.A . Dragracing.
posted January 29, 2011 06:54 PM
You won`t be able to upshift unless you are riding or the back wheel is spinning....It won`t allow you to up shift by just sitting there.....
swolldaddy
posted February 01, 2011 04:38 PM
i haven miss up the crank can i put in new bearing ,
0.22912311553955 seconds processing time
