BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Honda Releases All New 2011 CB1000R Streetfighter NEW TOPIC NEW POLL POST REPLY
posted November 02, 2010 05:35 AM        Edited By: Staff on 2 Nov 2010 17:10
American Honda release their all new 2011 CB1000R, derived from the 1000RR. This bike is Honda's entry into the naked class, now served by all the OEMs. The 1000RR engine appears to have been re-tuned for the street, while the chassis features a reappearance of Honda's signature single sided swingarm.
Honda says:
American Honda Motor Company's Powersports Division announced to its dealers today the release of the CB1000R, a high-performance and versatile "naked bike."
"Last week we introduced the all-new entry-level CBR250R and we're just as excited about this addition to Honda's lineup for 2011," said Powersports Press Manager Bill Savino. "The CB1000R fills a great position in today's market as we now bring a very capable sport machine packed with high-performance features to riders who focus on street use—wherever and whatever their destination may be. Whether it's a quick trip down a favorite backroad, a weeklong ride through a few states, or anything in between, the CB1000R is versatile enough to do it all."
More detailed information and images of Honda's model line can be found on powersports.honda.com or see your local Honda powersports dealer.
CB1000R: A Distinctive High-Performance Honda
When you look at the new CB1000R, you see a motorcycle with roots that stretch back to the seminal four-cylinder classic CB750K0 introduced by Honda in 1969. Yet at the same time the CB1000R carries a sporting heritage so modern that it will attract many of today's most sophisticated and demanding street riders.
Credit its clean, essentials-only styling, and a fuel-injected four-cylinder 998cc powerplant tuned for loads of right-now power. Sophisticated Gravity Die-Cast technology creates a mono-backbone aluminum frame that is strong yet features thin-wall construction for light weight. The distinctive single-sided aluminum swingarm features a single rear shock with spring preload and rebound-damping adjustability for excellent rear suspension action. And there's a fully adjustable 43mm inverted fork and radial-mounted dual 310mm disc brakes up front. Perhaps best of all, the roomy seating position delivers excellent rider comfort and tremendous versatility for long-distance travel and two-up riding. With all these features and more, the 2011 CB1000R is the most modern iteration of a long line of much-respected high-performance unfaired four-cylinder bikes—the classic hot-rod Hondas. Available in Pearl Black beginning in Spring 2011.
Features
Look at the new CB1000R and you see a motorcycle with an enduring correctness of design. This is a motorcycle with roots that stretch back to the seminal four-cylinder classic CB750K0 introduced by Honda in 1969, a heritage that will resonate with a remarkably wide span of today's most sophisticated and demanding riders.
Credit its clean, essentials-only styling, a fuel-injected four-cylinder 998cc powerplant tuned for loads of right-now power, single-sided swingarm with single-shock rear suspension, plus a wealth of new features that give it its own unique identity. Whether you choose to call it a "naked bike," or a Superbike in Clark Kent clothing, the 2011 CB1000R is the most modern iteration of a long line of much-respected high-performance unfaired four-cylinder bikes—the classic hot-rod Hondas.
* The CB1000R powerplant features a sport/racing heritage in the form of a compact, lightweight and powerful 998cc liquid-cooled fuel-injected inline four-cylinder engine that has been specifically retuned for a street-savvy ride with impressive amounts of low-end and midrange power.
* The crankshaft, main shaft and countershaft are situated in a triangulated configuration, with the countershaft located below the main shaft, to dramatically shorten the overall engine dimensions from front to back.
* Racing-derived 16-valve cylinder head delivers outstanding flow for optimum combustion characteristics and power production.
* Aluminum composite cylinder sleeves are high-pressure formed from sintered aluminum powder impregnated with ceramic and graphite. The lightweight composite sleeves provide enhanced wear resistance and superior heat dissipation compared to conventional sleeves.
* Programmed Fuel Injection (PGM-FI) continuously monitors several variables to ensure the correct fuel mixture for the existing riding and atmospheric conditions, thereby delivering optimal performance and remarkably crisp throttle response over a wide range of operating conditions.
* Sophisticated Gravity Die-Cast technology creates a mono-backbone aluminum frame that is strong yet features thin-wall construction for light weight. This innovative technology forms the basis of a well-integrated chassis package that yields superb handling.
* Distinctively styled single-sided aluminum swingarm with single HMAS shock featuring spring preload and rebound-damping adjustability provides excellent rear suspension action along with a unique look.
* Up front, a fully adjustable 43mm inverted fork with radial-mount dual 310mm disc brakes sourced from the CBR1000RR offers leading-edge sport bike performance.
* Standard seating position delivers excellent rider comfort and tremendous versatility for long-distance travel and two-up riding.
* Short, compact and lightweight seat and tail cowl are both attractive and functional.
* Compact and stylish three-section LCD instrument panel features a multi-segment LCD tachometer.
* Distinctive triangular multi-reflector headlight, with unique LED position light.
* Distinctive cast aluminum wheels feature a swept four-spoke design.
Specifications
ENGINE
Engine Type: 998cc liquid-cooled inline four-cylinder
Bore And Stroke: 75mm x 56.5mm
Induction: PGM-FI Fuel injection with automatic enrichment circuit and 36mm throttle bodies
Ignition: Computer-controlled digital transistorized with 3-D mapping
Compression Ratio: 11.2:1
Valve Train: DOHC; four valves per cylinder
DRIVE TRAIN
Transmission: Close-ratio six-speed
Final Drive: #530 0-ring chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension: 43mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travel
Rear Suspension: Single gas-charged HMAS shock with spring preload and rebound damping adjustability; 5.0 inches travel
Front Brake: Dual radial-mounted four-piston calipers with 310mm discs
Rear Brake: Single 256mm disc
Front Tire: 120/70ZR-17 radial
Rear Tire: 180/55ZR-17 radial
DIMENSIONS
Rake: 25.0 degrees (caster angle)
Trail: 99mm (3.9 inches)
Wheelbase: 56.9 in
Seat Height: 32.5 inches
Fuel Capacity: 4.5 gallons, including 1.0-gallon reserve
Curb Weight: TBD
OTHER
Emissions: Meets current EPA standards. Models sold in California meet current CARB standards and may differ slightly due to emissions equipment.
Colors: Pearl Black
MSRP: TBD
epd345
posted November 02, 2010 07:19 AM
WOW looks just like an FZ1!
posted November 02, 2010 07:35 AM
Has a single sided swingarm which is cool.
Ricksgsxr
posted November 02, 2010 07:50 AM
Kinda like and working on me. Good sign to see some new fresh models getting released maybe sorta a psychlogical boost for this shitty ecomomy and gloom and doom to see some new stuff and the exhaust is not a total fugly design, not perfect but not bad
1badzx12r
posted November 02, 2010 08:18 AM
looks like a slim down bking to me
Big_T112
posted November 02, 2010 12:11 PM
Whats up with the transformer style? and why do they always have to de-tune the bikes? I think they should take a hint from the auto industry and go throwback. Make a modern version of the late 70's early 80's supersport models. Now that would be cool. But I do like the new Honda.
posted November 02, 2010 12:31 PM
Honda Vmax .. cool
Hellmutt
posted November 02, 2010 06:13 PM
Its bout time honda, but it looks like they crossbred a Z1000 with a BKing
Meangreen14
posted November 02, 2010 06:41 PM
It kinda looks like an MV agusta Brutale
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
posted November 02, 2010 08:22 PM
Nice bike, glad Honda didn't opt for the shaft drive. Is it detuned for N America? Or did they find a way around that like Aprilia and BMW
zixxer14
Damn that was Quick
posted November 02, 2010 09:28 PM
Sorry but totally fugly, exhaust is beyond description, at least you won't have to flatten it for corners and why do nakeds need to look like transformers? Total Loser. Next.
MotoCycho
posted November 03, 2010 11:45 PM        Edited By: MotoCycho on 4 Nov 2010 07:47
Honda can call it "new" all they want. but it's been out since '08 all over the world 'cept north america. I know cuz in '08 I had wood over this bike and was hoping they would bring to the states for 3 years now. Then along came the redesigned z1000 for 2010.. and well.. the cb1000r is old news now. Got my order in for a 2011 z1000 now. Honda was just too slow IMO. Already obsolete!
Here ya go.
Shogun
posted November 04, 2010 06:15 AM
That would have been cool a few years ago when streetfighter styling was popular.
Next thing you know Honda will release a factory chopper to jump on the new Orange County Chopper craze that's sweeping the nation....check that...already done with the Fury.
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
Hellmutt
posted November 04, 2010 07:43 AM
Streetfighters are HUGE overseas.........it's the hottest thing since toilet paper!
Freedom
04 ZX12r.
posted November 06, 2010 03:06 PM
I like the rear rim on that Honda.
A closed mind is like a closed book, just a block of wood.
0.62647485733032 seconds processing time
