BIKELAND > FORUMS > ZX12R ZONE.com > Thread: have u ever changed your throttle position sensor NEW TOPIC NEW POLL POST REPLY
zx12mark
posted October 12, 2010 12:21 PM
if so,what was the bike doing that lead up to the replacement.i have 50,000 miles now and i think mines shot.
riteristrob
posted October 13, 2010 02:04 AM
I didn't change mine, but it was out of adjustment. Symptoms were rough idle, frequent stalling at stop lights, when I would get on the gas it would sometimes have a bad hesitation like the ignition was turned off for a split second, backfires on decel, surging when trying to run at a constant speed.
There is a thread on here with really good instructions for adjusting it, but if you've tried that then maybe it is shot. I think the service manual has procedures for testing it. You'll need a digital voltmeter to adjust it properly.
zx12mark
posted October 13, 2010 08:27 AM
thanks for the responce.i have over the years set it.it specs out to the service book.i`m hooking up with a buddy that has a scope to check for bad windings or segments in the tps device.i`ll let you guys know.my 2000 12 has 50,000 miles on it now............
tuusinii
posted October 14, 2010 11:44 AM
Not personally but my friend is just about to change it - we allready have a new one. The sumptons were bad running and when testing the sensor was way off - something like 1,6V when it should be 1,084V at idle. We adjusted it to the right valua but this year it went back to high.... So check Your voltage and that the transition is smooth when You open the throttle. And there is also an upper limit in the manual.
JoeGibs
posted October 15, 2010 11:29 PM
do you happen to have a link to this thread? i tried searching, but got a million results
02 Fightered R1
03 Project ZX12
riteristrob
posted October 16, 2010 07:59 AM
Here's the link. I followed entropy's steps.
http://www.bikeland.org/board/viewthread.php?FID=1&TID=31987
posted October 17, 2010 09:35 PM
doug points out on that thread that there are 2 completely different operations discussed
1. setting the TPS of the bike, then afterwards
2. setting the TPS for the Powercommander
(if you don't have a PC, then ignore those comments)
0.21885013580322 seconds processing time
