BIKELAND > FORUMS > ZX12R ZONE.com > Thread: No start NEW TOPIC NEW POLL POST REPLY
kiwi12
posted October 03, 2010 10:33 PM
No start
Ok, i am lucky im bald, because i would have pulled out all my hir by now,,,,,,,,
I have just changed my main loom, ( as I was having voltage drop )
and in doing this I dropped the engine, and removed the old loom. and replaced with a second hand 2002 loom,
my bike is a 03.
i took off the fuel tank, and replaced once the engine was back in the frame.
i did disconnect the tps, , and everything eles that was attache .. but have replaced everything back to the new loom.
w
Now when i turn the ignition on, all i get is the clocks starting up, but no fuel priming, or no starter motor,,
i stll have the radiator off,
any helps
,, please ,,
what is going on in here?
woppi
posted October 03, 2010 10:50 PM
did you mount the minus wire at the engine ? is near the clutch cover !
take a look at all fuse´s !
are the wire at the batterie good fixed ?
kill switch - handlebar ok ?
are all the plugs at the engine + sidestand fixed ?
1st TFA Member / Austria !
2000 Limited ZX12R NOS
kiwi12
posted October 03, 2010 11:26 PM
everything has been plugged back in, earth is plugged in,
fuse,s all good, even checked 30amp in battery box.
will check stater /kill switch.
it was working ok, just before the loom swap
woppi
posted October 04, 2010 04:04 AM
let me ask ? stupid ?
you change the complete cable loom ? yes ?
do you use the "old" ignition switch ? ??
the sidestand plug is ok ??
the clutch lever switch is ok ?
the engine is not moving ?
kiwi12
posted October 04, 2010 11:37 AM
I changed the main loom,, not the injecter loom, or the headlight, or ignition
and i used the old ignition.
i asume the side stand and clutch are ok, (I have bypassed just to double check)
and there is no starter moter or fuel priming,/ only the gauges work, and brake lights etc
tuusinii
posted October 04, 2010 09:39 PM
Does the neutral light show that it's in neutral?
kiwi12
posted October 04, 2010 11:31 PM
yep neutral coms on.
tuusinii
posted October 05, 2010 12:44 AM
Try cleaning the ignition switch with contact cleaner. If there is bad contact. Have You checked the "immobilizer" wire on ignition switch that routes +12V to the ECU via resistor?
0.23480200767517 seconds processing time
