BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Dumb question after dumb actions! NEW TOPIC NEW POLL POST REPLY
Chango
posted August 07, 2010 09:40 PM
Ok I had a streak of idiotic actions. I ran my bike while low on oil hitting the 11 grand on the RPMs and it over heated and ticked real bad before dieing on me. After a oil change (no metal in the oil) the bike stopped ticking but still ran hot and the starter would not restart the bike when hot. Drained the coolant and ran distilled water through it. Now it does not run hot but the starter will not start it after it gets hot. So I opened up the starter and brushes and armature are in good condition. So my next guess is the battery. Its a gel battery and I just got it last year! But that's my next step at this point.
My question is could this be a bearing issue? The bike runs strong until it gets hot then it the starter can't turn it over.
What do you guys think?
Stuart Racing
N.H.R.A . Dragracing.
posted August 08, 2010 05:38 AM
Sounds like it`s trying to seize the engine. What happens, it just won`t turn the egine over fast???
Drp
posted August 08, 2010 05:42 AM
Bearings spring to mind.
Chango
posted August 08, 2010 09:57 AM        Edited By: Chango on 8 Aug 2010 17:59
Damn I was hoping you wouldn't say that! It will slow crank a few times before no turning at all from the starter. It's sad because when it runs it runs fine revs and every thing. but then when you heat it up and turn it off the starter can only move it slow a few times before stopping. I going to try giving it a jump when it does that and see if the battery isn't giving enough to crank it!
Tazio
posted August 08, 2010 10:37 AM
I suspect it's just a bad battery.
Tazio
posted August 09, 2010 05:40 AM
Yep, buy a new battery...
NINJA12
posted August 09, 2010 10:29 AM
can you boost it off when hot?
0.27955913543701 seconds processing time
