BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bike is dead no power wont switch on NEW TOPIC NEW POLL POST REPLY
zx-12ster
posted August 01, 2010 05:45 AM
Hello forum, im a zx12r owner for 8 yrs now,(2002) pearl mistic black, need help on a problem that came up yesterday and it is kickin my butt. Rode the 12 for about 2 miles came home parked the bike in front of the garage it sat out about 4 hrs, went to get on it and hit the starter button it turn over 1 time and the bike went dead.No power dash wont light up or nothing. Pluged it back up to the battery tender, tried it again and still no power.Anybody ever had this happen ,so forum give a zx12r brother a hand.
ZXLNT
posted August 01, 2010 11:32 AM
Did you actually check the battery voltage?
aliveagain
posted August 01, 2010 02:26 PM
There are 2 fuses in the battery box along with the fuses on top of the frame.
zx-12ster
posted August 01, 2010 05:09 PM
I checked the voltage later after the tender said it was charged the volts said 10.1 volts. So im assuming the battery is bad, all the fuses I've checked are good, so I'll buy another 1 tomorrow.Thanks guys.
tuusinii
posted August 01, 2010 09:23 PM
Yes definately the battery is out at 10.1V Check also the alternator connector below the riders seat that there isn't oil in it. And check the voltage after the battery change so You can see it's loading. Should be around 14 V with engine running.
NINJA12
posted August 02, 2010 01:22 PM
check the main fuse in the battery box while you got the battery out.
hotmix
PIMP
posted August 03, 2010 04:50 AM
Yeah the battry box fuse blew on me and i didnt even know it was a fuse in it.
but it blew and nothing worked
zx-12ster
posted August 04, 2010 02:21 PM
Hey guys, I want to thank all of you for your input. I checked all the fuses like everyone said,all the fuses were good, after all this it was a bad battery, I want to say thanks forum I know when I need a hand where I can go. THANKS AGAIN (ZX-12STER)
The_ShadowKnows
posted September 03, 2012 03:40 PM        Edited By: The_ShadowKnows on 3 Sep 2012 23:41
I have the same problem today. I went to start it. It turned over for about 1 second and then nothing. No dash, no lights, no electrical. Battery is good, reads 12.8 volts. All fuses are good including main fuse. Power appears to be ending somewhere past the fuses. I thought I would look online and find something. Without a schematic I don't know where to look.
Dennis
The_ShadowKnows
posted September 03, 2012 03:41 PM
Dennis
tuusinii
posted September 03, 2012 09:45 PM
Check the main battery cable that goes trough battery tray. Mine was ones loose.
The_ShadowKnows
posted September 10, 2012 11:31 AM
Connection appear to be fine. Could it be the relay?
Dennis
0.22686696052551 seconds processing time
