BIKELAND > FORUMS > ZX12R ZONE.com > Thread: how to flush the raditor NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted July 20, 2010 07:09 PM
how do you go about flushing the system, i have the raditor off now puttin the muzzys fan on and doin some other things but would like to obvisoly like to flush. So A how do i do it???? B What type of fluid should i put back in
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
ZXLNT
posted July 21, 2010 02:22 AM
Should be a drain bolt down by the water pump. Remove it and use a garden hose in one of the upper hoses and flush until clear water comes out. I use Engine Ice myself..
Bobbydigital17420
posted July 21, 2010 07:29 PM
Rossi
posted July 22, 2010 08:08 PM
Left side caseing in front of the shifter. The bottom bolt. I just did mine so if you need help or a pic let me know.
Bobbydigital17420
posted July 23, 2010 10:22 AM
thanks rossi i pulled the bolt and let it drain i have the raditor off and draind that also draind the over flow, now what, never done this on a bike befor so thanks for your help
tuusinii
posted July 24, 2010 01:48 AM
There is also an drainage bolt on the block. It's on front left, 10mm bolt, below exhaust in the lower part of the cylinder. It's wice to drain that too so You get as much of the old fluid out as possible.
ZXLNT
posted July 24, 2010 01:32 PM
You saying even though the water pump is below the level of the cylinder block, it holds water in the cylinder?? Is it the angle of the cylinders that holds the water in?
Rossi
posted July 24, 2010 04:01 PM
Hey Bobby did u get everything?
Bobbydigital17420
posted July 24, 2010 07:03 PM
bike is back together now jus add the fluid??? wat else should i do???
whitehendrix
fails!
posted July 24, 2010 07:42 PM
add coolant. start up without cap. look for leaks, run for a minute without cap on and add coolant as the shit circulates and purges air pockets out. once it's topped off, cap it, ride it, stop it let it cool, check the coolant level again and top off as needed.
then you're golden.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
Chango
posted July 24, 2010 08:56 PM
I know this is suposed to me a easy job but I'm a nube and I'm a visual person. could you post a pic please!!
thanks in advance!
tuusinii
posted July 24, 2010 11:21 PM
Yes there is maybe half a litre of water in the cylinder. It' probably because of the angle if You think how the water passages are in the cylinder. Anyway it's just on bolt and you anyway hhave the lower cowling of so no big deal if you know it's there.
Toni
Rossi
posted July 25, 2010 09:24 AM
Send a PM and I can send the stuff on it from the service manual. Just make sure you flush it to make sure you get the old stuff completely out if you have'nt. Bleed it with the same bolt u drained with before filling it up to the neck and running with the cap off to get the bubbles out. Also tap on all the lines that connect to the rad. while doing this to make sure all the bubbles come out.
2000redrocket
posted July 25, 2010 11:15 AM
also mark the level in the puke tank at first cause it should pull more in than it pushes out unless you have a leak someware and when the water in the engine cools down and shrinks it pulls air instead of water..
0.29663991928101 seconds processing time
