BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Need an 02 flywheel NEW TOPIC NEW POLL POST REPLY
fraydknot
posted July 19, 2010 04:31 PM
Need an 02 flywheel
Hi all, I'm a newbie to the forum and was referred by a friend to seek a much needed part. Anybody got a good used flywheel for a 2002 ZX-12R? My magnets are weak and it won't charge sufficiently. Contact me if you or someone you know has one.
Thanks in advance!!
posted July 19, 2010 04:33 PM
How did you determine that your magents were weak?
Check Ebay if nobody chimes in.
fraydknot
posted July 19, 2010 04:38 PM
I had the infamous headlight issue then replaced the stator with one from Rick's. This fixed the headlights butaccording to the service manual it should be producing 85-120 volts @ 4k rpms. I'm only getting 68-69 volts. I teach MSF courses for the military and I'm told the heat can really destroy the charging system. Am I wrong in my thought process? Thanks for any and all help.
fraydknot
posted July 19, 2010 04:42 PM
Oh yeah, the voltage reading (68-69) is directly out of the stator.
posted July 19, 2010 04:51 PM        Edited By: Shane661 on 20 Jul 2010 00:52
Well, I am no expert. But I have never heard of weak magnets being an issue, nor the flywheel. I don't think heat will weaken magnets?
Some smarter folks than me will chime in, I'm sure.
fraydknot
posted July 19, 2010 04:56 PM
It is odd to think but everything else checks out fine. The new stator and battery have about 20 miles on them. When I rode it to teach a MSF course I noticed after a few starts, as it heated up, it was hard to start till it cooled. I only have 17k miles on her.
posted July 19, 2010 04:57 PM
Did you check the stator connector in the tailsection? They fill with oil and melt.
fraydknot
posted July 19, 2010 05:01 PM
yes and minimal oil was in it. the new stator came with a plug too. no signs of heating up in the plug either. I'm stumped and getting frustrated since I can't ride it for prolonged rides. I've had her since day one and this is the first problem I have had.
ZXLNT
posted July 20, 2010 03:58 AM
Weak magnets can happen but it is fairly rare. Perhaps the stator is/was weak from Rick's. I would sure try and borrow a rotor before I bought one though..
fraydknot
posted July 20, 2010 04:09 AM
Yep, I've contacted Rick's to see if there have been any issues with weak stators being purchased. Will update as I chip away the stone. Thanks for the advice ZXLNT!!!
0.24450993537903 seconds processing time
