BIKELAND > FORUMS > ZX12R ZONE.com > Thread: frame gromet holes NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted June 30, 2010 04:31 PM
frame gromet holes
what did you guys use to seal the frame holes that hold the plastic pieces covering the ram air tubes and wires?
posted June 30, 2010 06:54 PM
JB weld
2000redrocket
posted July 01, 2010 03:38 PM
sounds good to me.
posted July 01, 2010 03:43 PM        Edited By: Shane661 on 1 Jul 2010 23:44
I put aluminum duct tape over them. With the small surface area of the holes there is no way they will leak. Of course, if you want to run your ram air covers, that could be an issue.
2000redrocket
posted July 01, 2010 04:13 PM
yes shane i am going to JB weld them bu putting masking tape inside and filling them up about 1/3 the way and pull the tape out after it sets. sofar it is either weather clutch or my 3 ram air leaks slowing me down. the engine has plenty of compression i think at 225 to 235 psi cold.
posted July 01, 2010 04:17 PM        Edited By: Shane661 on 2 Jul 2010 00:24
posted July 01, 2010 04:24 PM
Given those options, it's the clutch. The ram air leak from those holes is nothing at dragstrip speeds, imo.
You wouldn't even see .5 psi at the dragstrip, under best conditions.
When troubleshooting a problem...look at what has changed, or could have changed.
2000redrocket
posted July 01, 2010 04:53 PM
been this way since may 7th. either way i know my bike is in good shape when it gets back together.
got the shinko hookup today. one word "NICE" for 120 bucks on sale. i should of got two.
0.36241412162781 seconds processing time
