BIKELAND > FORUMS > ZX12R ZONE.com > Thread: bleedin front brakes???? NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted June 29, 2010 07:03 PM
ok so ive been runnin on front rotor cause one of the was very worped..finlly got me some new rotors so im puttin back on the other caliper..im usin the sotck line that i took off gonna be gettin the braided lines soon... but how do i bleed them been out there for about an hour and a half and i still have no pressure...went threw 3/4 bottle of fluid dot4 is there some kind of trick to this??
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
Rock4173
posted June 30, 2010 09:03 AM
I use a vacuum bleeder its so much easier it lets you bleed both calipers at the same time. The last time I had to do that it took me a while even with the vacuum bleeder.
aliveagain
posted June 30, 2010 06:02 PM
Maybe you have a leak. Try taping you brake lever to the grip as far as it will go and walk away. Come back the next day and try it again.
0.23291802406311 seconds processing time
