BIKELAND > FORUMS > ZX12R ZONE.com > Thread: steel/hard.alum/alum sproket? NEW TOPIC NEW POLL POST REPLY
mach111
posted December 16, 2002 11:20 PM
from experience aluminium is the lightest and dosnt last long.is the hardened aluminum as light and does it last longer.i use steel up front,whats the best back one?
flite leader
posted December 16, 2002 11:33 PM
REAR SPROCKET
i ordered the 46th
alum with TITANIUM(hard) finish
i dont drag race
i do ride fast
typically dont have pro blems with chains or sprockets
keep them adjusted properly & lube after each ride
works 4 me
bend your mind.....
or break your ass...!!
posted December 17, 2002 10:56 AM
I only ride lightly on the weekends...... and the aluminum works great, I have used the annodized and now I have a race billet sprocket. works great.
Mad Mike
ZHooligan
Post Whore Extraordinaire!
posted December 17, 2002 08:09 PM
I run a 520 set up with my under powered 1361. I use a steel in front and Titan tough Aluminum in the rear. Sprocket Specialties offers Titan Tough as a option. Some kind of Aluminum hardening process. Worth the $10 buck upcharge in my book.
I would be suspect of MadMike. He only rides on the weekends!!!! Low miles too I'll bet!
posted December 17, 2002 09:04 PM
LMAO...... ok here is a picture of my sprocket, sorry not a great one but will do.
Mad Mike
ZHooligan
posted December 17, 2002 09:22 PM
Are those the pants you wear to church on Sunday?
fastestr1
posted December 18, 2002 12:14 AM
That is a kool looking spocket what kind is it and what gears are you running?
Black 02, 8.99 @ 161.95 motor on NOS
Put one knee down for the curves and both knees down for GOD
posted December 18, 2002 05:28 AM
Z actually I do wear them to sunday morning services,, and the the sprocket is a PMFR, but I have had it polished, and I run 17-51.
MM
ZHooligan
posted December 18, 2002 02:42 PM
Mike... PMFR? Do they have a website or is there an particular distributor you recomend on the PMFR sprocket. The sprocket looks pretty nice. If I read the photo corectly it appears you are running a Masterlink with a clip and not a peened master. Is that corect? What's the red spot for on the chain?
posted December 18, 2002 03:30 PM
I called them direct, but I dont have the # handy check out dragbike.com and look under the equipment section/parts, I cant rember what exactly it is but look at the top right of the page, oh there not cheap or for the timid. I have around 130 bucks in mine including having it polished, but it looks bad azz and they are made for drag bikes, or stock wheels. and I am runninga Tsubaki Sigma chain, and I actually have two master links, if you look close you will see a red dot and a black one next to each other, that is silicon to hold my clips in place so they wont fall/pop off, I have to replace my silicone every couple of races, I have had nothing but good luck with this set up! and if I want to change my gearing out it is alot easier! with diffrent chain lengths.
Mad Mike
0.25276803970337 seconds processing time
