BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Recharge rear shock ? NEW TOPIC NEW POLL POST REPLY
GOZR
GOZR
posted April 07, 2010 06:34 PM
I need to recharge my rear suspension on the 12 , anyone tried it already ?
I've read that i need to drill a small hole on the expension chamber plate to find the valve..
True ?
Thanks guys
S~
-G
psycho1122
posted April 08, 2010 02:32 AM
Race Tech did mine. Gold valved, new oil and recharged to 200 psi.
GOZR
GOZR
posted April 08, 2010 10:42 AM
Psycho Thanks and how much this cost you ?
No quick easy relcharge ( for this week end ) ?
-G
psycho1122
posted April 08, 2010 02:53 PM
No quick and easy. I tried a local "Suspention" guy and he did not have the resources to re-cap the remote rezi and recharge without it bleeding off the high pressure.
If I remember right, $200-400 should get you set up!
GOZR
GOZR
posted April 08, 2010 02:55 PM        Edited By: GOZR on 8 Apr 2010 22:59
Thanks Spycho, I'll check it out
Here i have already the LE front done.
Shock rebuild including parts -- aftermarket (Ohlins, Penske) $150
Rebuild stock OEM with airvalve $160
Rebuild stock OEM without airvalve $200
Shock rebuild AND revalve, aftermarket $225
Shock rebuild and revalve, OEM with airvalve $250
Shock rebuild and revalve, OEM without airvalve $295
http://www.le-suspension.com/services/shocks.html
-G
posted April 08, 2010 03:37 PM
I think i read in the 14 section that a dirt bike shop can just top up the nitrogen?
almost_les
posted April 08, 2010 05:04 PM
the original setup just has a rubber stopper and you use a needel to add pressure. not to mention that when you take that chrome cover off you see that it is actually recessed inside and the "reservoir" is mostly just for looks. i had a local guy do mine with shortening, revalve, respring, and reservoir cap (non-recessed, and proper valve) for about $300. talk to the local road racers and they usually know of decent suspension guys. thats how i found the guy that did mine.
GOZR
GOZR
posted April 08, 2010 09:27 PM
Nice
Thx
-G
psycho1122
posted April 10, 2010 05:36 AM
Yep! That's my set up! Same Race Tech Cap etc.
LE does good work also I hear.
posted April 17, 2010 04:23 PM
So guys, what are we looking at here? can this be easily topped up with the "needle method" or do i need to have a different valve put in?
0.26538610458374 seconds processing time
