kaw12
posted March 09, 2010 12:30 PM
another clutch question
i got the 01' model and never changed the hub to an 02 or later. so, i need some help. i already talked to another forum member and he gave me some very insightful points and instrutions as well as other threads started in the past.
what i dont get is or what in the heck do i order when looking for the steels and fibers. i was told the 01 model had 2 sets of chatter plates. 1 in the back and 1 sett in the middle. so i was told i didnt need the middle set, that being said? what steel or fiber goes in its place to make of the space? if replacing the hub, i think i will just replace the whole clutch pak.
do i just buy all 2.0 steels and "certain fibers, i dont know.
also this is first time pulling clutch hub. do i need a hub puller?
another clutch question.
thanks everyone.
posted March 09, 2010 04:05 PM
http://www.bikeland.org/board/viewthread.php?FID=1&TID=49121&set_time=1257615227
you dont sound like a drag racer so use oem parts
sohel
posted March 09, 2010 05:17 PM
hey scott, I bought a billet muzzy basket and was ggoing to change it along with the plates and the muzzy hub, had a question about the part where I need to aligning the clutch gear , before removing the basket. 1st do I need the special tool (clutch gear setting) and what exactly am i aligning the 'hole B' with ?
posted March 09, 2010 05:47 PM
the gear on the back of the clutch basket is not solid, its 2 pieces that have a spring to make them try to not be ligned up. this makes a tight and quiet fit on the crank gear that turns the basket. all you really need is to find a screwdriver that fits in the hole and you can pry the gears to be ligned up very easily. this makes removal and installation very easy
sohel
posted March 09, 2010 05:54 PM
okay great thanks. one last thing do I keep pressure on the gear when lined up and pull the basket at the same time?
kaw12
posted March 09, 2010 06:03 PM
what was i saying.
wylde
posted March 09, 2010 07:09 PM
dont pull the basket first,, take a small bolt that fits the inner bearing sleeve ,, screw the bolt into that and pull it first then the basket will come out without a single problem like butter!
do the same thing in reverse when putting the basket on,, basket on first ,, THEN the sleeve!
There you go again,,NOT being aware of yourself !
