wylde
posted March 06, 2010 04:02 PM
Edited By: wylde on 7 Mar 2010 00:06
All i can say is WOW!!!
spent 7 hours in the garage today as we had temps in the 50s,,, put the velocity stacks in,, hooked up a illuminated manual fan switch,, and also hooked up the New WEGO4 and dialed it all in,, everything went without a hitch,, took it for a blast and she is a little lean now,, made the adjustments to the map and will take it out again tomorrow to see if she is on the right track! :here is a video
http://www.youtube.com/watch?v=c15UFP7qD-k and this is what the Log file looked like after the ride:
and after the fuel correction is refreshed this is what i ended up with, , SO after the numbers above were adjusted and loaded into the powercommander the map looks like this to date,, with a few more adjustments to go im sure!
all i can say is what a fucking difference! thing is running PHENOMINAL! http://www.youtube.com/watch?v=Xzivve4Qg8cstay tuned.. more to come.. if anyone has anything to add,, please do so as i am still learning ,, but i think im on the right track
There you go again,,NOT being aware of yourself !
wylde
posted March 06, 2010 04:07 PM
Edited By: wylde on 7 Mar 2010 00:10
tried to post a you tube video,, what did i do wrong? it posted on the other board at kawiland?
