BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch Thumping?? NEW TOPIC NEW POLL POST REPLY
beansbaxter
posted November 16, 2002 10:34 AM
Clutch Thumping??
Ever since I had that Muzzy Clutch Kit put into my 12, it does pull harder as I release the clutch going into the gears. However...
It does seem that the gears thump into the next gear a lot harder then the norm. It doesnt matter how high or how low on the tach, but when I engage the clutch to shift, the shift is a hard shift, like a thump into gear, if that makes sense.
Is this because of the Muzzy clutch or what? It just seems hard on the gears, and I dont know what I should do about it.
posted November 16, 2002 01:04 PM
Check your clutch adjustment in accordance with the owner's manual.
beansbaxter
posted November 18, 2002 10:42 AM
The only adjustment for the clutch I see is the at the cable end, since it is not hydraulic, for adjustment of the play in the lever.
Where else should I look please?
0.23084592819214 seconds processing time
