BIKELAND > FORUMS > ZX12R ZONE.com > Thread: oil leak NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted December 16, 2009 05:53 AM
oil leak
Oil coming from wiring harness located on the left side of the bike by the rear subframe,I guess it need's to be sealed up?
Just another foeteen!!!!!
posted December 16, 2009 06:22 AM        Edited By: Shane661 on 16 Dec 2009 14:22
Common problem...wire harness from the stator needs sealed. Connector at subframe should be inspected for heat/damage internally. I did away with the connector.
1badvespa1400cc
power junkie
posted December 16, 2009 08:51 AM
Any pics,what did you do with the connector or what did you use to reconnect the wires?
posted December 16, 2009 08:59 AM
I don't have any pics. I cut the connector out, soldered the wires, and then sealed them with shrink tubing.
My stator loom was sealed on recall, I believe.
1badvespa1400cc
power junkie
posted December 16, 2009 09:25 AM
I'm glad I don't have this problem with my 14!
woppi
posted December 16, 2009 11:49 AM
take a look at
http://www.bikeland.org/board/viewthread.php?FID=1&TID=39399
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
0.25891613960266 seconds processing time
