BIKELAND > FORUMS > ZX12R ZONE.com > Thread: compression ratio Muzzy 1361? NEW TOPIC NEW POLL POST REPLY
catman12
posted November 14, 2002 12:59 PM
Someone know what is the comp. ratio with 1270 pistons machined for 1361, as it is when you bye from Muzzys?
I have heard both 13:1 and 13.5 :1 !
What is the comp. ratio for Muzzy 1361 kit with 1270 pistons, (no machining)?
Someone tried both?
/ Mikael
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
posted November 14, 2002 01:12 PM
Check with Mad Mike, He built his that way.
Doug
catman12
posted November 14, 2002 01:28 PM
Doug or someone else! I will recieve my kit next week, do you know if the "standard" is 13.5 : 1 or 13: 1 ???
/ Mikael
supraman95mb
posted November 14, 2002 07:09 PM
Anybody? What comes with the standard 1361 kit? What compression ratios are there on the standard and the 1361 with 1270 pistons?
02 Stroked 12R
95 Supra Single Turbo 750+ hp
jason370
posted November 15, 2002 01:28 AM
got me?
'02 ZX12 black/gold
  Ignore this member    Click here to send jason370 an AIM message.
catman12
posted November 15, 2002 05:45 AM
someone?
kawair
posted November 15, 2002 09:19 AM
C'mon, Doug - give us a little more info !
kawachan
posted November 15, 2002 09:32 AM
1270 kit http://www.muzzys.com/ZX1270-S/index.html 13.5:1
1361 kit http://www.muzzys.com/ZX1361/index.html 13:1
RED NINJAS RULE!!
kcadby
posted November 15, 2002 11:00 AM
That's what it says in the "add" but the motor I built (1361-13:1) was less than that...
I don't think MadMike knows the exact comp. of his motor when he built it...Mike???
The owner of the company I work for...won't let me post much about what I do HERE...
ZHooligan
Post Whore Extraordinaire!
posted November 15, 2002 11:07 AM
My 1361 using the the 1270 pistons, stroker crank, the shim plate provided by Muzzy for the stroker motor and a standard thickness head gasket measures out at 14.2 to 1. Not exactly your get on it and ride to California on pump gas engine.
future; -- Youth is forever.
kawair
posted November 15, 2002 11:20 AM
14.2 to 1 - Yow ! Don't want to get caught fueling in the boonies at Jim Bob's Discount Gas ! I'm contemplating doing this (Reg. 1270 pistons w/ stroker crank) but that might be a little much.
frEEk
posted November 15, 2002 11:45 AM
14.2:1, would it be ok with 94 gas?
catman12
posted November 15, 2002 12:21 PM
Anyone know if there are supplied cyl base gasket and shim under the cylinder on 1361 kit?
Anyone who have NOT installed the gasket?
/ Mikael
posted November 15, 2002 12:22 PM
I installed the spacer plate, but no gasket. My 1347 stroke is just a smidge shorter than a 1361 motor.
catman12
posted November 15, 2002 12:33 PM
swht, Have you had any problem with leakage?
0.27533912658691 seconds processing time
