BIKELAND > FORUMS > ZX12R ZONE.com > Thread: first real problem my 12....?????? NEW TOPIC NEW POLL POST REPLY
beansbaxter
posted November 03, 2002 04:15 PM        Edited By: beansbaxter on 3 Nov 2002 16:17
First real problem with my 12....??????
I've encountered the first real mechanical problem with my 12 while out riding today.
To try to accurately describe the problem...when I give the bike throttle, the tach and speedo climbs like normal, until about 7 grand and the tach just free revs and takes off. I've given all the play I can out of the clutch, since its cable, and it still is posing a problem with acceleration and free revving.
The bike tops out in 6th gear redlining at only 120mph. When I give it gas, the tach just uncontrollablly zips ahead with no acceleration on the speedo. It's like the bike has no power, at all, no matter how much gas I give it.
Full throttle and still no quickness, no quick power, like I've been accustomed to always having ready to dispense.
Is the problem my clutch or what? Is it covered under my warranty or are they going to try claiming it's normal "wear and tear." I'm going to try to take into the dealer this week, wanted to hear what it could be. Thanks for any help.
And if it matters...mine is an 02 model with about 12000 miles on it.
Diverig
posted November 03, 2002 04:38 PM        Edited By: Diverig on 3 Nov 2002 16:42
Sounds like a clutch to me.
As for the waranty I don't think the stealer
will spring for a new clutch.
ninja12
posted November 03, 2002 04:54 PM
Yeap the clutch is gone. Riding it can only lead to problems at this stage.
The fibers are going into the oil and can cause serious engine damage.l
wannabe
posted November 03, 2002 05:34 PM
I agree. Rebuild the clutch.
ZHooligan
Post Whore Extraordinaire!
posted November 03, 2002 05:39 PM
You need a new clutch! And with 12000 miles warranty isn't going to cover it.
future; -- Youth is forever.
beansbaxter
posted November 03, 2002 05:47 PM        Edited By: beansbaxter on 3 Nov 2002 17:50
Ok, now I definitely know for sure the problem thanks to everyone's feedback.
So now I ask, if it's just the clutch....should I order an aftermarket one or go for another stock one? Any chance it could be more then just the clutch that I'll have to worry about?
The Muzzy clutch kit is $300...ouch! For just a clutch?????
posted November 03, 2002 05:53 PM
Go price the stock one, then come back...
beansbaxter
posted November 03, 2002 06:00 PM        Edited By: beansbaxter on 3 Nov 2002 18:03
And I was going to ask if I need the Muzzys Performance Clutch Kit by itself or do I really need the billet clutch basket also?
Looking up various parts of the clutch system on Ron Ayers...it looks a lot more exspensive to get another stock one, yet I'm not sure what parts I need? Does it vary or is pretty standard which parts of the clutch will need to be replaced?
HUB-CLUTCH? $71
HOUSING-COMP-CLUTCH? $249
Looking at those two pieces alone, I think the Muzzys complete setup is a whole lot cheaper.
posted November 03, 2002 06:36 PM
You would need to purchase the clutch hub and the friction plates and steel plates. And you still wouldn't have as reliable clutch as a muzzy clutch.
redelk
Please... speak to the hand.
posted November 03, 2002 07:02 PM
Just playing devil's advocate, unless it's in someway damaged, you wouldn't "have to" replace the hub. At least not in most cases. So, you could just replace the friction and steel plates for about $175 and even though this isn't "absolutly necessary", you could thrown in new OEM springs for around another $12. With shipping from Ron's, you'd probably get out for under $200.
Not to dis Ron, because those are GREAT prices for these parts, BUT... for $100 more, you could get "a new precision drilled clutch hub, hub bearing sleeve, friction plates, heavy-duty drive plates and heavy duty springs. " (quoted from Muzzy's site).
When it comes time to replace my plates, this is the route I'll go.
-Ernest Hemingway
wannabe
posted November 03, 2002 07:35 PM
Hey Beans,
Just curious...how many miles do you have on your 12, and how nice are you to the clutch? I just want to get an idea of how long it took for your clutch to fail.
moodybluezx12r
posted November 03, 2002 09:19 PM
clutch....
Raleigh, NC
Ride it! Like You Stole It!
  Ignore this member    Click here to visit moodybluezx12r's homepage.
beansbaxter
posted November 03, 2002 09:51 PM
SERIOUSLY.....thanks to everyone for the great advice/help here in this situation. I will be going ahead and getting the Muzzy Performance Clutch Kit for my 12 and go for the install myself to save some money.
I drove probably about 80 miles on the bad clutch...of course now its parked until it's replaced? Did I do any damage to the engine in regards to the fiber getting into the oil too much already?
I just had the oil changed about 400 miles ago...do I need to replace the oil and filter again after I put the new clutch in?
What do you need to soak in oil the night before the clutch install??
To wannabe....I have just under 12000 miles on my 12. I am actually really conservative of a driver. I drive a lot, am hard on the clutch a couple times a month, nothing too bad.
beansbaxter
posted November 03, 2002 10:06 PM
How is the Muzzy Clutch Kit by the way? How many miles should I get out of it? How is the quality in the from the springs to the plates? Is it worth every penny or should I consider something else?
wannabe
posted November 03, 2002 10:51 PM
I just bought the Muzzy kit myself. I have the part sitting on my kitchen table right now. Let's see if I can expand a bit on what the kit consists of and how it helps. From what I've read from multiple boards, the fibers and steels are both stock. (i.e. the same stuff you can get from Kawasaki) The only difference is that the steels that are in Muzzy's kit are the thicker 1.6 mm type. The ones that come stock on the 12 are 1.4mm. The thicker steels are supposed to be able to take the heat better without warping.
The part that makes the kit worth it is the hub. (There's a bunch of archived threads here somewhere that show it all.) It's just like the stock one, but there are holes and channels drilled in various places to allow oil to lubricate the fibers. Just in case you didn't know, the 12's clutch is notorious for going bad due to oil starvation.
Here's a link to the threads:
Archived Clutch Threads
I hope this helps..
ZHooligan
posted November 03, 2002 10:56 PM
I must be bad luck. I met with Bean on Friday in Pullman. Daniel is a man!!!He rode his 12 over to my daughters place to meet me. It was about 25 degrees! Jeans and a his Vanson jacket! All you guys talking about those 38 or so degree rides need to talk with Bean.
Hells Dark Lord
living life, and loving it.
posted November 03, 2002 11:19 PM
when ya redo the clutch, make sure to clean the pick up screen for the oil pump, and change the oil and filter, had a buddy of mine lost a motor from the clutch fibers clogging the pick up screen and depriving the motor of oil...better safe than sorry
silvrnick
posted November 04, 2002 04:41 AM
I had the same problem..My clutch went out at 1500 miles. I took it to my stealer and they talked to Kawasaki and they covered it. But with the miles you have on yours they are going to try to ram it in you. My stealer quoted me $650 for the complete stock clutch!
zxlnt
posted November 04, 2002 07:42 AM
Actually the Muzzy has the 2mm steel plates. Stock are 1.6mm
beansbaxter
posted November 04, 2002 08:48 AM        Edited By: beansbaxter on 4 Nov 2002 08:57
Z.....your no bad luck, I assure you of that. It was fun meeting you and your daughters. I could have talked motorcycles with you for days, very cool!
beansbaxter
posted November 04, 2002 09:25 AM
I just put my order into Muzzy for the clutch kit.
TedG
posted November 04, 2002 01:01 PM
Make sure you change the oil when you replace the clutch pack. All that material had to go somewhere.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
beansbaxter
posted November 04, 2002 01:08 PM
Yep....I ordered the Muzzy clutch kit, but I didnt get the billet clutch basket so is it safe to assume the stock one will work fine?
your car is slow
Fuck Nitrous...Got Boost?
posted November 04, 2002 01:25 PM
After seeing a stock clutch basket out of the bike....I ordered a billet one the following week.
Thing lookds like it was made out of tinfoil.
Do not taunt happy fun ball!
zxlnt
posted November 04, 2002 02:56 PM
That aint no shit. If it was billet it would be fine, but that cast stuff just breaks to easy..
0.29108190536499 seconds processing time
