BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Off topic ... computer / brower problem... NEW TOPIC NEW POLL POST REPLY
posted October 28, 2002 07:09 AM
driving me totally nuts... IE werks, mozilla and kazaa cant establish a network connection... what gives? Has IE somehow locked up my system so that I cant use anything other than their crap?
Serious input only please... a solution would be much appreciated.
blkrnbow
posted October 28, 2002 07:59 AM
Any proxy or Firewall between you and outside world?
Brian
posted October 28, 2002 08:05 AM
firewall... no proxy... problem still exists if I bypass firewall.. kazaa etc werk on laptop and other machines behind firewall... only nfg on main computer (of course the one I want it to werk on).. so, no it's not a firewall issue unfortunately
pat830
posted October 28, 2002 08:37 AM
I dumped my KaZaA. I think it was interfering with my PC and it loads a ton of spyware onto the PC that is running it.
posted October 28, 2002 08:47 AM
it's not a kazaa issue..
SPEEDCRAVER
posted October 28, 2002 08:55 AM        Edited By: SPEEDCRAVER on 28 Oct 2002 08:56
Did you just upgrade to IE 6?
I have seen a lot of issues with IE 6, but I cant say that this is the cause for sure. I would have to Look into it further.
I keep all of my guns loaded, to many people die from unloaded guns.
posted October 28, 2002 08:56 AM
no... ie 5.5
posted October 28, 2002 08:57 AM
I did recently install a MS service pack update... if I knew how to remove it, I would (incase that's the prob)... but I have no idea
SPEEDCRAVER
posted October 28, 2002 08:58 AM
I used mozilla with 5.5 and it worked fine. Did you upgrade or install anything recently????
posted October 28, 2002 08:59 AM
read the post above yours...
SPEEDCRAVER
Did you check the backup my files box during the installation of the service pack? If you did you can revert back, if not you are screwed.
SPEEDCRAVER
posted October 28, 2002 09:00 AM
I am a slow typist.
posted October 28, 2002 09:06 AM
IC
zx12zx11
posted October 28, 2002 09:54 AM        Edited By: zx12zx11 on 28 Oct 2002 09:58
I'm running XP, IE 6.0 and KazaA works fine. Sorry that I can't help.
DaveInDaytona
posted October 28, 2002 10:02 AM
Doubt it's an update problem but I'll ask, did you apply service to the OS or the browser ?
Go to a command prompt and ping a known address and see if it can resolve, like "ping bikeland.org"
I assume this is a home thing and when you say firewall you're talking about some DSL or cable box and not a "real" firewall product ?
FYI pat830, kazaalite doesn't do spyware.
DaytonaSportbikes Forum
posted October 28, 2002 10:27 AM
no...it's a real firewall.... and as I said before ie and ftp and all of my other apps work... mozilla and kazaa lite wont... even if I bypass the firewall... they run on my other machines... just not the one I want them to run on.
DaveInDaytona
posted October 28, 2002 11:28 AM
Win2000 with a new SP3 install ?
DaveInDaytona
posted October 28, 2002 12:06 PM
or XP SP1 ?
DaveInDaytona
posted October 28, 2002 12:12 PM
If it's XP SP1 try this to fix Kazaa:
Right click on the program file (the executable), then select the compatibility tab.
Check the box labeled "Run this program in Compatibility Mode for" and select Windows 98/ME from the dropdown menu.
Then click "apply" and then ok.
Try to run kazaa again.
posted October 28, 2002 12:46 PM
98 se... and the problem isnt just with Kazaa.. it's with mozilla as well so there is a "greater" problem at foot here
DaveInDaytona
posted October 28, 2002 01:41 PM
I saw that, but you didn't specify the OS so I had to guess. If that fixed the kazaa problem then I could tell you how to fix the others. There is a known issue with XP SP1 and W2K SP3, I'll have to look on 98 because I didn't expect to see that OS getting a new service pack.
zx12richard
The Green Monster..
posted October 28, 2002 01:44 PM        Edited By: zx12richard on 28 Oct 2002 13:45
You can turn off the spyware.. Goto start, hit run, type in msconfig,click startup tab and clean out the spyware.... This site will help tell you what you can eliminate stuff you don't need to free up systems resources...
http://www.pacs-portal.co.uk/startup_pages/startup_full.htm
http://www.pacs-portal.co.uk/startup_content.htm
posted October 28, 2002 04:27 PM
this isnt a spyware issue.. and no dave that option doesnt exist with 98
bagster
posted October 29, 2002 07:33 AM
cleaned your registry lately?
Try window washer or EasyCleaner.
you never know what whacky things might happen with a misguided registry.
posted October 29, 2002 07:56 AM
will try.. thanks
0.23986196517944 seconds processing time
