BIKELAND > FORUMS > ZX12R ZONE.com > Thread: SUSPENSION SWAP NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted August 30, 2009 03:38 PM
SUSPENSION SWAP
can i take the suspension from a 2004 (forks and rear shock assembly) and put it on a 2000 zx12r????
  Ignore this member    Click here to visit BALTIMORE410's homepage.
posted August 31, 2009 05:33 AM
Just rear shock YES...If whole rear assembly then u have to use the dog bones from the 2000...
Front forks are exactly the same...
posted August 31, 2009 06:37 AM        Edited By: Shane661 on 31 Aug 2009 14:38
I believe the 04 forks have the radial mount brake calipers?
posted August 31, 2009 06:45 AM
Thats right Shane, I forgot about that...
posted August 31, 2009 03:14 PM
no real need to swap the rear unless you go for aftermarket, for the front, it would be a good brake upgrade. I think you can switch to zx14 calipers then?
BALTIMORE410
posted August 31, 2009 09:30 PM
WHAT ALL WILL I NEED 2 DO THE SWAP?
hyper12r
posted September 01, 2009 10:31 AM
04-06 fork ,n spacer cause of 00-03 bigger rotors..
0.27363109588623 seconds processing time
