BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Welding Cast? NEW TOPIC NEW POLL POST REPLY
Cowboy
posted October 21, 2002 04:41 PM
Welding Cast?
I bought a wrecked bike for parts and see that the only damage to the frame is the tab that the fairing stay mounts to on the neck is busted off.Can this be welded back on?Is this cast alum or steel?I wanted to have this frame racked if I could.
zxlnt
posted October 21, 2002 05:15 PM
12R frame is aluminum ya can weld it.
Cowboy
posted October 21, 2002 05:37 PM
The neck is cast.Can you still weld that?
ZHooligan
Post Whore Extraordinaire!
posted October 21, 2002 05:44 PM        Edited By: ZHooligan on 21 Oct 2002 18:45
I have always been afraid to weld on the frame. So I usally drill and tap or drill and put a thread sert in. Not sure if that works in this application, but if it does it sure beats the heck out of welding!
future; -- Youth is forever.
Cowboy
posted October 21, 2002 05:56 PM
I agree with not enjoying the idea of welding on the frame but in this case there is not enough left to work with.It is almost broke clean off+welding will have to be done anyway to rack it.
frEEk
posted October 21, 2002 06:28 PM
one of those tabs broke off on my bike too. was concerned about the welding issue as well. if u do get it welded before me, can ya let me know how it worked out? i'd hate to think i have to get a new frame cause of one tab.
Zx23rr
Mahogany Bomber Pilot
posted October 21, 2002 07:02 PM
At the risk of sounding like a nut - (i am - but thats another story) if it isn't a highly stressed part, you could always try an epoxy - JB weld or Cold weld or heat resistant stuff. They have some neat shite out there now a days. Of course you have to decide if it will look the part afterwards. Some of the epoxy's are good to 3000 psi and more of shear strength.
Later......................................................................../
NINJA12
posted October 22, 2002 04:41 AM
Weld it, or sell it to me so i can.
Welding is the only true fix, but probably not at the muffler shop.
OZZY
need guberment cheese
posted October 22, 2002 05:17 AM
Cast will weld nicely IF you get a good experianced welder to do the job, preferrably with a tig machine and not a spool gun. The tig gives much better control of the weld. A good welder will preheat the area and control the cooling also.
"It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......HIT IT!"
Blues Bros.
TedG
posted October 22, 2002 10:09 AM
Welding the frame is not a big deal, as Ozzy says a TIG (GTAW) is the proper way to repair it. The best thing is to send the frame to a shop that specializes in frame straightining and have it repaired and checked for straightness. If it is only a tab just take it to the local welding shop and have it replaced. This is why I have a TIG in my garage, as a matter of fact I just wired it up a couple of weekends ago.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
kawachan
posted October 22, 2002 10:48 AM
That is the only thing wrong with the frame on my first 12 after I wrecked it. Welded it, painted it, and it was ready to go. Just an inherent weak spot on the front of the 12 frame. Better that tab to break than the frame neck, huh?
RED NINJAS RULE!!
zxlnt
posted October 22, 2002 10:50 AM
If Cowboy is taking about what I think he is. Its a rectangular shaped piece that is welded vertically against the front of the steering head. Its crossdrilled for the bolt to pass thru and hold the fairing bracket. It seems to be a pretty common thing for them to get broken off on wrecked 12R's. A friend had that was broken and he welded it back on. It doesn't seem to be a big deal with the proper equipment.
Cowboy
posted October 22, 2002 11:28 AM
Thats exactly what I'm talking about.Thanks for the info guys.I bought the bike thinking it wasn't a big deal but just wanted to make sure.
0.40912795066833 seconds processing time
