BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2004 ZX12R RUNNING LEAN NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted July 31, 2009 05:17 PM
how do you add fuel to the power commander....never really mesed with them but im a quick learner
  Ignore this member    Click here to visit BALTIMORE410's homepage.
posted July 31, 2009 05:38 PM
Im sure its running rich with the PC...
posted July 31, 2009 06:32 PM
it was on a dyno, so no its not
the numbers in the fuel map are how much its changed from stock, so if you see a 5, its 5 % richer at that spot, if its negative, its that much leaner than stock, zero is no change. a pipe will require some areas to be neg and some to be pos to run at the proper AFR.
do you know how to run the pc control center? there are tutorials on their website
0.23072600364685 seconds processing time
