BIKELAND > FORUMS > ZX12R ZONE.com > Thread: drilled basket NEW TOPIC NEW POLL POST REPLY
KINGKWIK
9.36@ 149.23
posted June 26, 2009 10:59 AM
drilled basket
2001 1290........Was wondering if anyone here drilled their own stock clutch basket?? Was looking at the muzzy and it doesn't appear to be an exact science...plz correct me if im wrong and any comments would be appreciated
thanks
If it has wheels or tits its bound to be trouble!!
posted June 27, 2009 08:46 AM
You mean drilled clutch HUB...
If you have a Muzzy drilled hub, then just duplicate the drilled area's...I recommend buying a 2002 & newer OEM hub then you can drill extra holes if you want...Muzzy used 2 different size drill bits in certain area's to keep the strength of the hub...
The hub Muzzy sells is now a 2002 & new hub which has the 6 large oil passages plus the drilled holes...
posted June 27, 2009 05:20 PM
yeah i did the one(hub) in dads to match my Muzzy hub
check this out http://kawasakiworld.com/racing/37186-not-enough-oil-clutch-pack-how-fix.html
0.24990510940552 seconds processing time
