BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ping nox or kzscott NEW TOPIC NEW POLL POST REPLY
johnzx12
posted June 23, 2009 11:43 AM
ping nox or kzscott
i have 2000 zx12 with bad cases-will 2002 cases work -i no stator cover is different on the inside- what would be the process of making this work-because if it a headache i will just order 2000 model but i heard the 2002 oil holes are bigger an they are about 75.00 cheaper - thanks for any advice
rquinn
posted June 23, 2009 11:54 AM
John it will work the oil runners in the 2002 are bigger than the ones in the 2000 and the 01 other than that have fun.
RON QUINN
posted June 23, 2009 05:11 PM
ive never used anything other than 00 and 01 first hand, but i think the cases are basically the same besides slightly different oil pipes?
you may need a different stator? Nox?
rquinn
posted June 23, 2009 06:54 PM
I did not have to change anything on mines but the oil runners everthing else I went back with and also a 2001 crank lighten and balanced.
RON QUINN
NOX
PMRA / TMRC Super Street 4022
posted June 23, 2009 09:58 PM
I do not know......
I have heard its all good.....
I am in the bad situation..., i have an 02, so I hear it would be bad ju ju for me to get early cases......
I am trying to stockpile right now, to build a 1290, with a hella head, and cams, and big compression, to run in Super Comp, at 72 inches with a 7 inch slick......, so I can slow it down and be easy on it to run the index.......,
But, I cant find a set of cases, might have to buy another used motor......., but, gotta go into the kids Jr. dragster and freshen it first........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
woppi
posted June 25, 2009 11:07 AM
what i know --- the different is ---
from year 00/01 --- to 02/-------
the oil pump -- the 02 modell oil pump goes ca. 2mm deeper inside the case
and the 02 modell has a fatter gear shift linkage ---- which come out if the case -- to mount the linkage of the footpeg
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
rquinn
posted June 25, 2009 05:37 PM
That may be true woppi but I went back with everything 01 except the oil runners.
RON QUINN
chavcat
posted June 25, 2009 06:08 PM
Ron - can you be more specific on the oil runners? Exactly the are you referring to?
rquinn
posted June 25, 2009 07:11 PM
Part number 39193A-1063 and also 39193A-1064 Pipe Oil RH and Pipe- Oil, Oil Pan
RON QUINN
NINJA12
posted June 26, 2009 08:12 AM
I bought used cases with runners, but I used everything from my 2000 engine also.
I know of a 2002 that was rebuilt with 2000 cases, he didn't say anything about case mods.
Let us know how it works out.
NOX
posted June 27, 2009 07:10 PM
Damn, I have passed up some good deals on early model cases......, but, should they be strayed away from?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
woppi
posted July 02, 2009 02:30 AM
take a look:
http://www.bikeland.org/board/viewthread.php?FID=13&TID=47996&set_time=1246530435
woppi
0.28883504867554 seconds processing time
