lynneric
posted June 21, 2009 08:21 PM
running lean
i have a 2003 zx12 with a full exhaust system and bmc air filter with usb power commander,, at 8000 rpm and up the bike is running lean i put it on a dyno and the power commander can make it richer enough to run proper its a new power commander, i tried it out on another bike to see if it was working proper and it was it have new plugs and the fuel pressure was at 41 at idle
posted June 21, 2009 11:24 PM
eric,
on the USB make sure it is set so the map applies to all 4 cyl, or if you are plaing with indiv sy, that all 4 maps are being modded.
I had the same situation you describe, and it was due to my USB being in indiv cyl mode and i was only changing one map
lynneric
posted June 22, 2009 02:09 PM
i took the power commander completely off and it still mess up
