BIKELAND > FORUMS > ZX12R ZONE.com > Thread: help ya boy out NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted May 04, 2009 05:24 PM
help ya boy out
i been b.s.ing for the last 2 weeks with this who wheels swing arm brake lines and pads swap ((weather been nice))
[IMG]http://i295.photobucket.com/albums/mm144/stillbugsy/003-3.jpg[/IMG]
  Ignore this member    Click here to visit BALTIMORE410's homepage.
BALTIMORE410
posted May 04, 2009 05:25 PM
man i dont know what the hell im doing im just putting s***t together kinda like a puzzle just mocking up for now i dont know torque specs or nothing but eh stay tuned it'll get done eventually
BALTIMORE410
posted May 04, 2009 05:26 PM
is this where this goes???
BALTIMORE410
posted May 04, 2009 05:27 PM
oldkawboy
posted May 04, 2009 08:26 PM
Stephen,
The torque specs will be in the shop manual, even though those parts aren't OEM they will be fine using the numbers out of the book.
That small spacer goes between the cushdrive and the wheel bearing on the left side. You can line it up with a screwdriver from the left side while installing the axle from the right side. I fabbed up an extra bearing to help with side loading while drag racing and it always worked great.
Put a drop or two of medium strength lock-tite on the rotor & sprocket bolts. With your engine work I'd put the smallest rear sprocket on the bike to start with. You can always gear it lower when you're used to the power. Remember that stock sprockets won't fit those wheels, you'll need to contact RC Components if you need something different than the three I sent you.
Let's see some pictures when you get it together.
Dan
BALTIMORE410
posted May 05, 2009 05:16 AM
Good lucking dan....I should have things started by friday
whitehendrix
fails!
posted May 05, 2009 08:01 PM
feel free to bring that bad boy to the shop!!!
i'll hook it up!
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
BALTIMORE410
posted May 06, 2009 01:46 AM
Where da shop at?
whitehendrix
fails!
posted May 06, 2009 10:21 PM
just past hagerstown.. in martinsburg right off 81.
probably a lil too far to really be worth it tho..
if i had my license tho i'd be out that way anyway gettin parts from my man dean at baltimore cycle salveage.
kinda sucks not being able to go where i want when i want.
i'll be more than happy to help how ever i can tho.
BALTIMORE410
posted May 10, 2009 11:07 AM
I SWAPPED OUT THE FRONT BLINKERS FOR FLUSH MOUNTS ALONG WITH CHANGING OUT THIS REAR FOR A UNDERTAIL......ALMOST DONE FINISHED WIRING THINGS UP JUST GOTTA PUT BACK TOGETHER WILL POST PICS WHEN DONE....ALSO CHANGED THE OIL OUT
0.21131300926208 seconds processing time
