BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Gearing NEW TOPIC NEW POLL POST REPLY
mouton38
posted April 30, 2009 10:41 AM
Gearing
I have a 240kit that's geared with a 17front sprocket. The kit came with a 45 rear sprocket. I think it needs to be a 47 or 48 to be able run at least 5 gears in 1/4 mile.
Kollen Mouton
BusaKilla
posted April 30, 2009 05:30 PM
is that a question?
mouton38
posted April 30, 2009 06:36 PM
I didn't know this was english class. I thought I would receive a comment about the statement. Anyway, what do you recommend for my set up????
Kollen Mouton
BusaKilla
mouton38
posted April 30, 2009 06:51 PM
Kollen Mouton
BusaKilla
posted May 01, 2009 09:03 AM
mouton,
what mph (more or less) are you getting in the 1/4 mile?
17/49, 50, 51, 52 all could work to cross the line in top of 5th, depending on how fast yr bike is.
Houston guy, eh?
I'm down in Mo City
Stuart Racing
N.H.R.A . Dragracing.
posted May 01, 2009 09:59 AM
I would think somewhere around what entropy just suggested would work just fine...I`m running 17/51 with a 200 SHINKO tire and stock motor.....Going through in 5th gear....
mouton38
posted May 01, 2009 11:03 AM
mouton,
Houston guy, eh?
I'm down in Mo City
Kollen Mouton
BusaKilla
mouton38
posted May 01, 2009 11:25 AM
On the 1/4 mile i didn't really look. I think it was around 135 or 140. on another forum there was some guys talking abou 16/46 gearing running 6 gears in the 1/4. Also heard if you go low on your front sprocket you risk breaking your chain. What's the truth. I also have spray 40 shot wet but hadn't got the other bugs worked out yet.
Kollen Mouton
BusaKilla
biggmoinc
posted May 01, 2009 05:08 PM
I run the 17t front n 47t rear on my 240 tire kit. I think on a stock extended bike they drop 1 n go up 4 which would b 2.88. But since u got the kit i would think u automatically dropped 1 in the front but also went from a 17 to an 18 inch rim on the back, so to get close to that gearing (2.82) u would have to keep the 17t n put a 48 on urs. I dont believe they even made a smaller offset sprocket for the tire kit for our bikes. Also ur miles per hour would b more at a certain rpm over stock tires (11k - 17/49 - 171mph) stock tires> (11k - 17/49 - 176mph) 240 tire, but ur roll out would take longer to get there. What tire u runnin, the pirelli? I see shinko now makes the 240 also. The metzler never hooked up well for me, mayb cause its more of a touring tire. Hope the info helps, i know it might have been a little hard to follow
biggmo@aol.com
mouton38
posted May 01, 2009 08:39 PM
Hey thanks, u hit on a lot of points that was thinking too. I just ordred a 48t. I'm already 17t in the front.
I'm running a dunlop tire. I ran low pressure and still couldn't get it to hook up. I also had some clutch issues
too. When I tried to launch at only 5 grand felt like the clutches were skipping. I was told to go Back with
Stock clutches. I dynoed and mapped at 159 hp to rear wheel. Whatcha think?
Kollen Mouton
BusaKilla
biggmoinc
posted May 02, 2009 04:40 AM        Edited By: biggmoinc on 2 May 2009 12:43
Mine had 161 wit pipe n pc without the 240, so i would say yes ur good, however some on this forum would say something different. It dont matter much on dyno, mph in the quarter is what i was told that tells everything, but i could b wrong. I just changed my clutches cause of slippage at high rpms, i went wit stock n 6 brock springs, lever is tight, lol, but oh well. I also got my stack height at 57.4 or something like that, its on the tall side, my clutch was a problem for years just now getting it right, n the worse part is i had to do it myself, the engine was built twice n both mechanics left them alone sayin they were in specs but when i checked the height it was 56 even. That is shorter than specs. I had a muzzy kit in it so i ended up swapping to oem fibers n swapping a few steels to makeup the difference for the stack height. Hasnt slipped yet, fingers crossed, lol. U got any pics of ur bike posted yet? I had a 48 on mine n went to a 46, now i got a 47, its ok for the highway riding, i think when i figured it out it was like 3 or 4 mph difference wit every tooth up in the back at a givin RPM. I think i read if u go to low of a sprocket in the front the natural bend of the chain is comprimised, maybe not in those words but u could search for it. Lots of info on this forum n I have asked alot of questions, lol. Sometimes even the same questions over again. But most of the guys r real cool n knowledgable, unlike the KATRIDERS forum my boy just joined, he put pics of his kat 600 wit a 240 kit n they were bashin him bad. Didnt believe him either. Forums should support not b negative, Check me out on Myspace/biggmoinc. Also for ur clutch problem, it may just need adjustment, Everyone says go exactly by the manual.
biggmo@aol.com
biggmoinc
posted May 02, 2009 04:49 AM
Here is a good calculator for u to find out what speed u will be at at a given rpm. U can select ur tire size n what gear n everything. All u need is :
Primary 1.596
4th gear 1.250
5th 1.130
6th 1.033
final 2.556 (46/18)
http://www.cosportbikeclub.org/misc/SpeedCalc.html
biggmo@aol.com
mouton38
posted May 02, 2009 07:07 AM
I've nev er been mechanically inclined to screw anything. I'm in houston (northside) where you at?
But I'm learning though. I'm putting on a nitrous fuel pump today. What's your email cause I'm technically retarded . Lol
I'm new to this forum stuff and I've never been on myspace. I got a lot of stuff to get done and quick. Cause I need to be runnin some 8.90's to 9.0's like yesterday.
Kollen Mouton
BusaKilla
biggmoinc
posted May 02, 2009 12:37 PM
Delaware, n dont say u dont know where its at, lol. my email is at the bottom of the post. But i would say to run those numbers u might want to put ur stock tire back on the back. It might b hard to do wit that 240 robbing us out of our HP! I get alot of smack for tryin to race mine, lol. U should already b stretched 6" or so wit ur tire kit, so strap the front n practice, also invest in air shifter, will give u a few tenths or so as well. Good luck
biggmo@aol.com
posted May 02, 2009 03:32 PM
your big tire is really holding you back from good ETs. way too much added rotating weight. run a 190 shinko u soft. 64-68 in wb, good shock, 17 50 gearing, hit the nitrous as soon as possible. try 3 stock springs and 3 hd in the clutch, set your stack height up correctly as per manual instructions
Phantom13
posted May 02, 2009 04:29 PM
The clutch "skipping" feeling is because you no longer have the 2 beveled anti chatter rings in the clutch assembly. I took them out when I replaced my clutch a while back and the clutch did exactly what you described... skipping. I put the two anti-chatter rings back in and now the clutch is perfect again.
Make sure you put them back in the right spots, check the ZX-12R service manual for the proper stack order and placement.
If you don't have a service manual, you can download one for free at kawasakiworld.com.
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
NOX
PMRA / TMRC Super Street 4022
posted May 03, 2009 07:17 PM
all depends on the hp level.......
I slow my bike down to run a 9.50 index 1100 ft above sea level......., 16/50, top of 5th......
going all out, I am top of 6th, same motor, no squeeze, just adding power with the pc,
Depends on what first gear you have too.......,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
Amazing......, I have been telling this to people forever...., finally someone did a back to back comparo.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted May 04, 2009 03:42 AM        Edited By: Shane661 on 4 May 2009 12:26
I didn't know this was ever in doubt??
I found this out a couple of years ago...a few clutch swaps...
Phantom13
posted May 06, 2009 05:49 AM        Edited By: Phantom13 on 6 May 2009 13:57
It was so easy, a caveman could do it. =)
I still can't believe how critical those chatter rings are! The clutch was not a happy camper without them, that's for sure.
0.24289894104004 seconds processing time
