BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Carrillo rod clearance on 1361??? NEW TOPIC NEW POLL POST REPLY
kcadby
posted September 24, 2002 07:21 AM
Who was it??? that used Carrillo rods in a 1361???
I know how I "want to" clearance the rod for the starter gear but...would like to know how it has been done by other people???
For the record...if you install Carrillo rods in the 02-ZX12R you need to use the early model (00-01) rod bearings because they ARE different and the rods that I got are made for the early Model bearings
posted September 24, 2002 07:31 AM
Zhooligan has carillos in his 1361. Prob is interference with the starter gear. The solution was shimming everything over a small amount, then it cleared.
kcadby
posted September 24, 2002 07:48 AM
Thank you SWFT...that was my plan of also
catman12
posted September 24, 2002 10:27 AM
Hi Guys! I have just ordered a 1361 Kit for my 2001!
As you have 1361 is it something special to think about when I assemble the motor?
What cam degree are you using?
I shall do some dragracing next summer is it necessary to bye billet clutch basket?
I have Muzzys clutch kit...
Thanks / Mikael from Sweden
www.kiruna.se/~mgrape
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
kcadby
posted September 24, 2002 10:41 AM
I would NOT run a 1361 without a Billet Basket!!!
Nothing else special yet...Muzzy's listed some cam timming #s here somewhere???
posted September 24, 2002 07:16 PM
Haven't heard of any numbers, other than the 105/103 numbers for the 1270.
posted September 25, 2002 02:31 AM
People with "STOCK" 12's are breaking their baskets! hence the thread about the trouble! As "PO" as I am, that is a considerstion! Plus everyone seems to gain a few hp! (Windage??)
posted September 25, 2002 04:23 AM
Mikael,
I used 105/100 on the 1361
Like KC said, do youself a favor and get the billet basket. Good insurance and it looks cool!
posted September 25, 2002 07:34 AM        Edited By: swft on 27 Sep 2002 08:45
When I built my 1347, I put the billet basket and Muzzy clutch on it. Although I didn't get to make that many runs down the strip (prolly two dozen) it still felt great, and I would definately recommend it for a stroked/bored motor.
kcadby
posted September 27, 2002 01:28 PM
I'd put the basket in a stock motor bike if I had the money
NINJA12
posted September 27, 2002 06:57 PM
"Zhooligan has carillos in his 1361. Prob is interference with the starter gear. The solution was shimming everything over a small amount, then it cleared. "
Not that i have Carillos, but what are you shimming and with what?
posted September 27, 2002 07:08 PM
I'll let ZHooligan answer that when he's back.
kcadby
posted September 28, 2002 12:16 PM
Shimming the torq limiter gear is the hard part...there aren't any shims to take out...somthing has to be machined in order to move the gear over (on THIS motor)...
I'm not done yet...or I'd tell you how I did it...
ZHooligan
Post Whore Extraordinaire!
posted October 07, 2002 07:45 PM
Just had a chance to review this thread.....
I have the carillos in my 1361. We had to shim the starter over and frankly Velasco also had to bevel the starter gear slightly as well. he had to also do some grinding in some other spots to insure clearance. I would suggest if you are putting Carillos in your 1361 motors (strokers) you might want to give Mike Velasco a call at MVR. I paniced when he started assembling the egine and the crank wouldn't rotate. Mike just handled it and it works great.
future; -- Youth is forever.
posted October 08, 2002 06:27 AM        Edited By: dougmeyer on 8 Oct 2002 07:27
When I used the Falicons in my 1340, I took the starter drive gear, chucked it in a lathe and simply with a file, took about half the width of the teeth off at about a 45 deg angle about 1mm deep at the "corner" of the tooth.Still plenty of engagement and the "contact point" (the pitch circle) of the gear is not touched. BTW- the interference is from the bolt head, not the rod itself.
Doug
ZHooligan
posted October 08, 2002 07:26 AM
Doug is correct the intereference with the Carillos is some of the bolt heads not actually the rod itself.
kcadby
posted October 08, 2002 03:00 PM        Edited By: kcadby on 9 Oct 2002 10:43
Thank you guys...
I have just about got this deal done (would BE done but...been a Dyno-n FOOL at work all week last week...
I DID machine (bevel) the gear but I was afraid to machine it "half way off" (the boss was also)... so I am also machining the case for the gear to be moved over
JFYI...it's not a rod bolt clearance issue...it's the big end of the rod itself...
Megabyte
posted October 09, 2002 10:19 AM
Carrillo rods
Anybody
How much weight do the Carrillo rods save over stock?
Is there any mod that would cause you to recommend sticking w/ the stockers on a 1361?
I know the Carrillo rods are lighter and stronger, but I've also read that the issue with the stockers in the end cap bolts t/f?
Zhooligan
posted October 09, 2002 01:04 PM
Not only are the rods stronger and lighter, the rod connection bolts are bigger and stronger as well. I don't remember the weght savings, but
swft posted some picks of the rods with weights etc. about 4 months ago.
ra12r
posted October 09, 2002 06:22 PM        Edited By: ra12r on 9 Oct 2002 19:30
Kevin, also double check the thickness of the case after you machine enough to clear particularly around the #4 on the bottom,where the bolt scrapes.!!! May need to be reinforced there, and also around #1 on the back once it clears. You don't need to shim the starter gear. Plenty of teeth left for the starter.
You will also have to machine the counterbalancer.........
ZHooligan
posted October 09, 2002 06:25 PM
What counterbalencer? If you are spending the money to have a 1361 motor spend the bucks to balnace the engine and throw the counterbalancer away. Less rotating mass. My bike is as smooth now without it as it was with it at least thats what my hands and butt remeber!!!
ninja12
posted October 10, 2002 06:52 AM
Kevin, any chance you could post a picture?
kcadby
posted October 11, 2002 09:36 AM
I am also removing the CounterBalancer...
The rods are 40grams!!! lighter (each)...
Thanks again for the info...
I don't have anywhere to post picture right now
zxlnt
posted October 11, 2002 11:45 AM
Send them to me Kevin and I will post them up for everybody
zxlnt@cox.net
posted October 11, 2002 08:03 PM
Muzzys has a nice anodized aluminum balancer "eliminator" plug that makes this an easy deal.
Doug
0.32327198982239 seconds processing time
