ted040
posted March 17, 2009 06:37 AM
Riching up fuel mixture
Hello again people, I need your help !!!!!!
Somewhere I read that some of you were changing your resistor value , thus tricking your CPU into a rich mixture.....
My question, where is this resistor....
The reason why I ask is because, when I start my bike from cold it seems to be over rich and runs like its overfueling. But when you finally take the fast idle off and let it idle it seems better.
The F.I light isn't on, but I think I might have a vacuum routing problem with my TB to my inlet air sensor and fuel pressure regulator.
Any thoughts >?????
posted March 17, 2009 02:29 PM
to richen the fuel mixture everywhere in the map you put a resistor on the orange wire going to the coolant temp sensor on the back of the head... but fix the hoses first
