BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2000 ZX12 vacuum hosing NEW TOPIC NEW POLL POST REPLY
ted040
posted March 11, 2009 05:39 PM
Hello dear Kawy friends.......
Just got a question for anyone who wishes to help me out...
I have a 2000 ZX12 which I took on as a project, and my question is on the four throttle bodies there are some vacuum ports (two) in question. I believe the cylinders 2 and 3 are hooked to the clean air valve and the #1 throttle body vacuum hose goes to the inlet air sensor and then tee's off to the fuel regulator ????
Does this sound right ????
The person before me had installed nitros so I currently have one vacuum port on each throttle body plugged off, because the nitros injector has been removed. The remaining vacuum port on each throttle body should be blocked off individually ???
And throttle body #1 is used for reference......
Any help appreciated......Cheers Ted
tuusinii
posted March 12, 2009 05:24 AM
Out of my head that sound right. Number 2 and 3 are definately hooked together and the to the KLEEN system and then there is one thats plugged and one goes inlet air sensor. Can check it up when I get to home.
0.23541903495789 seconds processing time
