BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Sring pressure with Muzzy lockup NEW TOPIC NEW POLL POST REPLY
keith
posted February 18, 2009 08:11 AM
I've got a feeling I've got too much spring pressure in my A1 Muzzy lockup. Does anyone have an installed guide pressure to aim for as a base setting. I've got three A1 springs and three Muzzy ones at the moment but the bike is very agressive on launch at times. I mean too agressive! Like exit stage left! I measured the installed length and it seems to be 40.5mm. Thanks guys. Keith
posted February 18, 2009 08:43 AM
wow no wonder you had to make the hydraulic conversion. how much weight are you running?
take out the HD springs!
almost_les
posted February 18, 2009 11:47 AM
i thought you were supposed to running less static with a lockup? all that pressure, plus the action of the arms is gonna make for some broken clutch pullers
NINJA12
posted February 18, 2009 01:46 PM
I never had problems with stock springs and no weights.
Try it and let me know what you think!
posted February 18, 2009 10:17 PM
yes, use less spring pressure than stock. i can pull my clutch lever in with one finger and im not built like arnold schwarzenegger, and no fancy hydraulic conversion. the arms start kicking in after about 15 feet. you dont need very much spring pressure. the arms do most of the work, and they dont need to be weighted. they are setup waay overkill from Muzzys or MTC. hint, i run less weight than 6 bare arms
keith
posted February 19, 2009 02:21 AM
Thanks guys, your replies confirm my feelings. I've had some wild rides over the last few seasons, I'm gonna try the stock A1 springs, which are lighter than the B model ones and will report back. Won't get to ride till April though because of the weather over here and then it may be wet. There's no fool like an old fool. Ha Ha, Keith
keith
posted February 19, 2009 07:53 AM
I had weight on three arms too so thats got to come off. Just trimmed my fairing back a bit more so I can get in there easily to add pressure and weight at my first race!!!!!!!!!!! Ha Ha
8 seconds here we come, haven't run one since 1975.
posted February 19, 2009 11:51 AM        Edited By: KZScott on 19 Feb 2009 19:52
keep dropping spring pressure untill you can snap the clutch lever out as fast as possible off the line(no slipping by hand) and drop weight untill your mph drops off, then add a tiny bit of weight. it will be way easier on parts. bare arms count as weight
ninja12
posted February 19, 2009 07:36 PM
Scott, That's advance tuning.
You got to get in the park first.
posted February 19, 2009 07:55 PM
think one finger pull on the spring pressure. the arms do most of the work. somewhere around half of oem spring pressure would get you in the park, then adjust from there. 3 stock springs and 3 muzzys springs are way out of the park, across the pond even . everyones setup will be different based on chassis, motor, power adders, bike weight, driver weight, driver style ect ect.
NOX
PMRA / TMRC Super Street 4022
posted February 19, 2009 10:36 PM
Your clutch set up is WAY off.
There is a goon on here who knows a little about tuning them......
His email is wilhiteracing@conwaycorp.net
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
keith
posted February 20, 2009 02:12 AM
Live and learn, my riding style is to drop the clutch off the line, I've always ridden that way, can't do the hand feeding thing. Nox, I've emailed your contact, thanks. Keith
NOX
posted February 20, 2009 05:46 AM
Thats the way you are supposed to ride a lock up.
I will get back with you.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted February 20, 2009 05:52 AM
I just checked, no email.
I will check later.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
keith
posted February 20, 2009 09:41 AM
I'll do it again, made a small error in the addy, doh!
NOX
posted February 20, 2009 03:42 PM
Replied to ya.........
Woppi and scott both will tell you< I know my shit on lock ups........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted February 20, 2009 05:21 PM
Thats where I come in.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.25845003128052 seconds processing time
