BIKELAND > FORUMS > ZX12R ZONE.com > Thread: off topic one more time NEW TOPIC NEW POLL POST REPLY
jason370
posted September 03, 2002 03:07 PM
my radiator fan on my dodge dakota wont stop. just keeps running no matter how cool the car is. is it a short, a fuse, or what. i suspect its an easy fix, i just dont know where to begin.
jason
  Ignore this member    Click here to send jason370 an AIM message.
TedG
posted September 03, 2002 03:11 PM
There are ususally 2 places on a car that will turn on the fan. 1 is the tempature sensor on the block or in the radiator. The other one is in the air conditioner. Thay both turn on a fan relay which in turn gets power to the fan. Find that relay and you probably have it.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
Wildman
I only look confused
posted September 04, 2002 07:09 PM
Does it run with the car off?
If so, the relay is stuck.
If it only runs with the car on, then it is probably a bad temp sensor. (Unless your car doesn't have power to the relay when the ignition is off, in which case it's probably the relay)
If you build something Idiot Proof, The world will build a better Idiot.
0.22658705711365 seconds processing time
