BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Rocker Cover Leak NEW TOPIC NEW POLL POST REPLY
Mauser
posted November 04, 2008 03:57 AM
Rocker Cover Leak
Hi guys,
Just wondering if anyone else had had a leak from their rocker cover ?, my baby has only done 6000 miles and last week she started missing, after much digging I found the left side spark plug drenched in oil, took the cover off and found the seals looked perfect no damage at all see picture below. Have refitted with 4 new seals and added a small amount of sealant around the rocker cover face and the cylinder head where the seals sit, just to make 100% they don't leak again.
Very tight working on the bike and didn't help with the reed valvebolts being impossible to get in or out.
Here's a picture in side.
madque6
posted November 17, 2008 10:52 PM
i know, i have 3 zx12r the (2) 2000 models leak in the left hand corner and they have less than 10k. the 01 dosent leak as of yet but it only has 1900 miles on it. did you pull the whole motor out?
  Ignore this member    Click here to visit madque6's homepage.
Mauser
posted May 06, 2009 02:46 PM
Sorry for the late follow up, no left motor in. The leak is still there and seems to be getting worse, bike started running rough so fetched plug out to find stick coil covered in oil.
Wondering now if the cover is getting pressurised from somewhere making the oil force past the seals ?, is this possible ?. Looking online at other leaking covers it does mention that pressure within the cover can cause a leak.
Where could I vent the cover easiest my baby is a B6F model so has slightly different Kleen air arrangment which has been removed and blanked with proper plates.
posted May 10, 2009 09:30 PM
I would look more at something that might be preventing the seals from doing the job they are designed for. A crack in the cover or head? A dowel that is too long, or cocked in the hole? A seal in upside down? A wrong bolt in a particular place that prevents the cover from seating? Wrong or damaged hold down bolts/washers?
If the seals are properly in place and the cover is held down correctly they won't leak. Internal pressure is not an issue (assuming crankcase vent is proper and not plugged).
Mauser
posted May 10, 2009 11:02 PM        Edited By: Mauser on 11 May 2009 07:04
Dougmeyer I have located where the leak is coming from, the vent hole which allows the spark plug to be removed easier must somehow be through to the inside of the cover
Using a compressor I pressurised the crank with the coil stick removed and air is heard coming from this hole, blocked it and no more leaks. When I next have the cover off I will take to my Kwak dealer and see if they will replace it.
posted May 12, 2009 12:06 PM
Your cover must be cracked. Some JB weld ought to fix that, at least for a while.
D.
0.24727702140808 seconds processing time
