shiggsy
posted November 02, 2008 08:25 AM
Benefits Of Datalogging
I fitted some Innovate Datalogging equipment last year so I could fit a powercommander and do my own mapping which has gone very well so far. One other thing I did was try to log as many of the bikes sensors and electrics as I could to act as a kind of OBDII system so if the bike developed a problem I would be able to spot or at least eliminate certain sensors straight away.
Well I got the chance to try that out this weekend as my bike suddenly developed a sever spultter at 3500rpm to 3800rpm in any gear, (revved was fine in neutral). Checking the datalog I could easily see where the problem was as the O2 Sensor traces were going crazy, but they were only consequential so removing those and all the clean trace lines I was left with the Injectors and Crank Sensor Lines. All 4 injectors were spikey with #1(red) being affected the most. But what are the chances of all 4 injectors going faulty at the same time. The crank sensor was also spikey in the same places and in places where the injector signal was clean. The Cam signal underneath (red) was also clean so it was looking like the Crank Sensor was faulty.
I went out and checked the ECU for any fault codes but there were none. I have a spare crank sensor to hand but before changing it I took the bike for another spin and really held it on the trouble spot. Again no ECU fault code but the same logging patterns so I swapped out the Crank Sensor and went for a test ride. Problem solved
How much time and money and faffing around would that have taken to fix without the datalogger, testing sensors, swapping parts around, buyng new parts etc etc. How cools is that, diagnosed in the time it took me to drink 1/4 of a cup of coffee!
posted November 02, 2008 11:08 AM
shiggsy,
VERY cool!
How did you log the crank sensor and injectors.
i am about to try the same thing
karl
posted November 02, 2008 11:42 AM
Im watching this one too! awesome work!
shiggsy
posted November 02, 2008 01:38 PM
I'll try and explain but it'll sound more complicated than it is and won't make much sense to anyone who hasn't got any of this kit.
I have the Innovate boxes sitting on top of the ECU in the tail section so I tap into the wires about 6 inches from the ECU.
The injectors are fairly straight forward, the Devices Input Channel needs to be able to support a 'Duty Cycle' Configuration. The DL32 has 3 channels that can do that so I have DL32 Channels 3,4,5 reading injectors 2,3,4. I also have 2 SSI4's which takes 4 sensor inputs each so I have Injector 1 going to an SSI4 Channel 2 . You only need to connect a negative injector wire to the channels Positive input, the Channels negative input can remain empty. Using LM Programmer you then configure those Devices Channels to measure 'Duty Cycle' .
In Logworks, for viewing the datalog, the configuration can the be set as below for each injector. (After I added a power commander I stopped using the ECU injector wires and tapped into the PowerCommanders output wires so it would pick the changes and also keep an eye on the Power Commander)
On the ZX12 the Crank and Cam Sensor both output out a sine wave so you need to use a device that has VR Channel, (the DL32 doesn't have one of those) but the SSI4 has 1 so I have my Crank Sensor wires going to one SSI4 VR Channel and the Cam sensors to the other SSI4, (the cam sensor will only registers above about 2000rpm because it only has one tooth ).
In LMProgrammer I have the VR Channel for the Crank Sensor configured for Frequency and have the Frequency set to 1583Hz (I'll have to check that though). In Logworks I have that channel configured as below so the Crank signal doubles as my RPM Signal.
posted November 02, 2008 09:21 PM
sounds very complex. i dont think i have enough hardware to do it, i just have the LM1 and LMA2 (rpm kit)
shiggsy
posted November 03, 2008 04:09 AM
I haven't used those devices but I just skimmed through their manuals and I think your right, they don't appear to have the capability to read the Injector or VR Signals.
posted November 03, 2008 08:58 PM
do you know if its possible to tap into the power commander wiring harness to monitor duty cycle?
shiggsy
posted November 04, 2008 01:12 AM
Don't think its possible with your devices, same signal, same problem.
posted November 04, 2008 08:51 AM
damn... why cant everything be a nice 0-5v signal? lol
